Adj Gears w/ Stock Cams?
Old Jun 27, 2002 | 09:25 AM
GSxRated's Avatar
Default Adj Gears w/ Stock Cams?
I want to add a little more power to my car before the next drag day but dont really want to spend the extra $500 right now to get a set of cams. Would it be worth it to get adjustable gears to run on my stock GSR cams or should I wait to get the whole package and not waste my time right now? I'm also upgrading the FPR and Fuel Rail if that helps. Thanks.
Old Jun 27, 2002 | 09:32 AM
Fooser's Avatar
Default Re: Adj Gears w/ Stock Cams? (GSxRated)
It will help a little if you get it tuned on a dyno. Dont expect huge gains but there will be minimal ones due to your I/H/E. Advance your ignition timing to 18 degrees as well when you race. I dont know if the Fpr and Fuel rail will help you because you wont really need to up the fuel pressure for your current mods. Its a good upgrade tho. maybe look into a high flow cat.
Tuning will help you get that edge you need. Tune tune tune.
[Modified by Fooser, 6:34 PM 6/27/2002]
Old Jun 27, 2002 | 09:35 AM
GSxRated's Avatar
How much is not much, 3-5whp? Would I be able to get anyting for my stock GSR Cams?
Old Jun 27, 2002 | 11:39 AM
Malice's Avatar
New User
i got 14whp on my Ls motor after adding and dyno tuning cam gears on stock cams
Old Jun 27, 2002 | 11:41 AM
GSxRated's Avatar
Default Re: Adj Gears w/ Stock Cams? (MaliceGSR)
Wow, was that w/ a tuned VAFC as well though?
Old Jun 27, 2002 | 11:45 AM
B-series Assassin's Avatar
That seems a little wild, especially on a non VTEC motor. What mods did you have before tuning the cams. Did you have a SAFC?
Old Jun 27, 2002 | 11:57 AM
Malice's Avatar
New User
Default Re: Adj Gears w/ Stock Cams? (B-series Assassin)
nope. just an intake and trust muffler on stock piping. went from 120 to 134.
Old Jun 27, 2002 | 12:16 PM
GSxRated's Avatar
Anyone have ideas what intake/exhaust should be set to on the stock GSR cams?
Old Jun 27, 2002 | 12:45 PM
Malice's Avatar
New User
all cars are different, so everyones settings are different. there are alot of fators into that. (elevation, temp,motor). here are some good facts tho. i quoted this from someone in the tech forum.
If you retard the intake cam your engine will breathe better at higher rpms but you will sacrifice low rpm performance.
If you also advance the exhaust you'll have more overlap and more time in between valve events. This will allow you to make more power up top.
I'll give you guys some numbers and general characteristics.
112 lobe separation angle gives good low end reponse e.g. RV, Stop N Go Apps.
108 lobe separation angle gives good gives good overall power. Street Apps.
105, 104 lobe separation angle gives good top end power. Drag, Land spped Apps.
For example the low lobes on B-series Vtec are 112 and the high lobes are 108 so you get very little compromise with these cams.
johnny_bighood
11
Apr 29, 2009 10:14 AM
Chris22215
May 10, 2004 01:10 PM
MugenPoweredLude
Dec 20, 2002 07:20 PM
AK94GSR
Aug 1, 2002 03:39 PM
fastwanabe
Apr 28, 2002 06:19 AM
