is there such thing as too much sticker weights?
Old Dec 14, 2007 | 06:53 AM
verycleanhatch's Avatar
Default is there such thing as too much sticker weights?
i recently got my tires mounted and balanced. the people who did it left the old sticker weights on it...... is that right? aren't they suppose to take the old sticky weights off?
Modified by verycleanhatch at 8:23 AM 12/14/2007
Old Dec 14, 2007 | 07:35 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: is there such thing as too much sticker weights? (verycleanhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch &raquo;</TD></TR><TR><TD CLASS="quote">i recently got my tires mounted and balanced. the people who did it left the old sticker weights on it...... is that right? aren't they suppose to take the old sticky weights off?</TD></TR></TABLE>
As long as the weights aren't coming off, they can leave the old ones on, and use that as a starting point in balancing. Did they add new weights as well? It would be unusual for all four tires to balance perfectly without needing to add or remove any weights.
Old Dec 14, 2007 | 08:10 AM
yeah they added new weights too. on one of my rims there was a sticker weight on top on another sticker weight. i have never seen that before.
Old Dec 14, 2007 | 02:44 PM
boostedwagon's Avatar
common protocol is to take the old sticky weights off. dismount the old tire, clean the bead (if its aluminum and crusty), replace valvestem, mount new tire, and finally balance. It sounds kinda hack to me if they did not remove the old weights. No two tires will balance exactly the same. If it were me I would take it back and make them re-balance them. Do they vibrate at all at highway speeds?
Old Dec 16, 2007 | 06:27 AM
shrtygt500's Avatar
Default Re: (boostedwagon)
++++++1 ^
Old Dec 16, 2007 | 01:48 PM
GYChris's Avatar
Default Re: (shrtygt500)
what he said ^^^^
there is such thing as too much weight on a wheel. you can balance them out but still feel a slight vibration. if there are too many weights. you are SUPPOSED to take all the old weights off when balancing, but what they did was counter balancing
Old Dec 16, 2007 | 02:46 PM
burke420's Avatar
alright... if they left old weights on, theyre dumb for one reason...recycled alum. is hella good money! and 2 they shouldve done it get them balance properly. now they counterbalanced,so go and say they forgot to take off old weights, and rebalance them right!
BryanM.
Feb 10, 2011 11:10 AM
diesel1245
Honda Motorcycles
Mar 7, 2007 03:25 AM
a2dadamm
Apr 19, 2006 10:36 AM
ForceFed Coupe
Dec 11, 2003 06:12 PM
igo4bmx
Sep 19, 2003 09:30 AM
