96 JDM ITR engines. If the head is stamped 95, is it still a type r motor?
Old Dec 13, 2007 | 11:52 PM
snowboardgeek1's Avatar
Default 96 JDM ITR engines. If the head is stamped 95, is it still a type r motor?
I just checked the head on my type r motor, and its stamped 95. Does this mean my motor is not a type r? Its also stamped PR3-2. I also see the green paint near the distributor, as well as a 30 stamped nearby as well. The IM is definitely a type r manifold. My block is stamped B18C. Just wante to make sure the motor is definitely a type R. Any insight?
Old Dec 14, 2007 | 12:01 AM
tartje's Avatar
Default Re: 96 JDM ITR engines. If the head is stamped 95, is it still a type r motor? (snowboardgeek1)
Type-R's were first available in August 1995
and there's nothing to say they weren't using head castings on cars from the year 1996 that were manufactured in 1995
Old Dec 14, 2007 | 12:05 AM
Default Re: 96 JDM ITR engines. If the head is stamped 95, is it still a type r motor? (tartje)
Ah, so Honda used 95 heads on 96 type r motors then. Interesting. Thanks.
Old Dec 14, 2007 | 12:36 AM
Fat Chick Magnet's Avatar
It was manufactured in 1995, but used on 1996 model just how tartje mentioned it.
Old Dec 14, 2007 | 12:37 AM
Default Re: (Fat Chick Magnet)
Right. My concern was just that I wanted to make sure that my motor was a type r. It definitely doesn't feel like a GSR but you can never be too sure. The 95 stamping threw me off.
Old Dec 14, 2007 | 12:39 AM
Default Re: (snowboardgeek1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboardgeek1 &raquo;</TD></TR><TR><TD CLASS="quote">Right. My concern was just that I wanted to make sure that my motor was a type r. It definitely doesn't feel like a GSR but you can never be too sure. The 95 stamping threw me off.</TD></TR></TABLE>
It's a ITR don't worry. That green stamp says it all.
Old Dec 14, 2007 | 12:41 AM
The green paint/stamp...I've heard that indicates those are the heads that Honda deemed worthy enough to become type R heads. Is that true?
Old Dec 14, 2007 | 10:11 PM
Natural Aspirations's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboardgeek1 &raquo;</TD></TR><TR><TD CLASS="quote">The green paint/stamp...I've heard that indicates those are the heads that Honda deemed worthy enough to become type R heads. Is that true?</TD></TR></TABLE>
IDK but my USDM B16A2 head had green on it. AFAIK the green doesn't mean anything, and is easily duplicated.
Old Dec 14, 2007 | 10:57 PM
Default Re: (Natural Aspirations)
Is your head stamped PR3-2 and is it stamped 30 near the distributor?
Old Dec 15, 2007 | 04:56 AM
Old Dec 15, 2007 | 09:01 AM
Stamped PR3-2 on the head? Where is the green paint on your head? I remember there was a thread where they indicated how to distinguish the characteristics of a type r head, and mine fit it all, but when I saw the head stamped 95, it brought up my attention.
Old Dec 15, 2007 | 11:43 AM
Oh I forgot to look for the Pr3-2 but it does have the 30 in it and had the green paint. I am 100% positive it came from a USDM B16A2. Honestly there is little difference between the two I wouldnt sweat it. Identify the cams and valvesprings by color(springs) and rings(cams). If you have the motor out of the car you can look into the intake ports and see the ITR valves vs the STD Vtec valves.
So you definatly have a B16/ITR head chances are its not a GSR motor with a B16 head.
Old Dec 15, 2007 | 12:58 PM
Yeah I highly doubt its a GSR motor with a B16 head. I really think its a type r motor. Its very strong....much faster than a GSR motor.
Old Dec 15, 2007 | 05:00 PM
B2FiNiTY's Avatar
green paint = itr head. If your b16 has green paint near the dizzy, might want to double check what internals the head has, it might be itr.
Old Dec 15, 2007 | 07:51 PM
Default Re: 96 JDM ITR engines. If the head is stamped 95, is it still a type r motor? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">green paint = itr head. If your b16 has green paint near the dizzy, might want to double check what internals the head has, it might be itr. </TD></TR></TABLE>
23k posts and you have problems reading still? I was positive it was a B16 head. It was pulled from an 00 Si my buddie was the original owner of. 00 head date PR3-4
Old Dec 15, 2007 | 09:59 PM
Default Re: 96 JDM ITR engines. If the head is stamped 95, is it still a type r motor? (Natural Aspirations
Ah....PR3-4. So that's definitely a B16 head? I know PR3-2 qualifies my head as an ITR. Why does honda have to make it so confusing? lol
Old Dec 16, 2007 | 01:44 AM
krytoi's Avatar
well my b16a2 is out of 99 si and the head is pr3 2 =]
Old Dec 16, 2007 | 01:48 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboardgeek1 &raquo;</TD></TR><TR><TD CLASS="quote">Ah....PR3-4. So that's definitely a B16 head? I know PR3-2 qualifies my head as an ITR. Why does honda have to make it so confusing? lol</TD></TR></TABLE>
the stamps on the head WON'T let you identify whether it has come from a Spec-R engine or not
Old Dec 16, 2007 | 05:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">
the stamps on the head WON'T let you identify whether it has come from a Spec-R engine or not</TD></TR></TABLE>
Old Dec 16, 2007 | 07:02 AM
I'm not saying thats the only deciding factor. I know there are other characteristics.
Old Dec 16, 2007 | 07:14 AM
Brewer's Avatar
Keep in mind, any '08 model available now would have been produced in '07 - so stamps are usually for the year before the model year
Old Dec 17, 2007 | 09:26 AM
ViSiONxBoY's Avatar
Default Re: (Brewer)
Characteristics of an R/B16 head.
Green paint
Stamped PR3-x or PR4-x
There is no SET PR3/PR4 stamp that guarantees it to be an ITR head.
So believing that a PR3-2 stamp will be an ITR head is completely incorrect.
You can't really tell the difference unless you rip it open and look at the valve springs like Natural Aspirations stated. Looking at the intake side IMO, but with carbon build up and doing that just to check the head it's a bit of a bitch. In most cases the, if it's a PR3/PR4 head mated to a B18C/C5 block. It's an R head, and I wouldn't be too worried.
Old Dec 17, 2007 | 09:55 AM
Default Re: (ViSiONxBoY)
Also I would think taking off the header, you can see if the head was ported a little bit. Correct?
Old Dec 17, 2007 | 10:18 AM
itrmyke's Avatar
i think the mild factory porting is only on the intake side.
Old Dec 17, 2007 | 10:28 AM
Default Re: (itrmyke)
I thought it was everywhere. Interesting.
