B16 NO VTEC
Old Dec 13, 2007 | 09:20 PM
d16_civic_07's Avatar
Default B16 NO VTEC
I GOT A 96 CIVIC DX I TOOK THE D16 OUT AND PUT A B16 BUT THE VTEC DOESN'T KICK IN HOW CAN I GET TO WORK?
Old Dec 13, 2007 | 09:21 PM
Redline it.'s Avatar
Default Re: B16 NO VTEC (d16_civic_07)
if the engines stock u dont really feel the pull with a b16...
Old Dec 13, 2007 | 09:24 PM
Default Re: B16 NO VTEC (Redline it.)
I HEARD THAT YOU CAN PUT A SWITCH TO IT BUT I DON'T KNOW HOW
Old Dec 13, 2007 | 09:26 PM
SOHCejcivic's Avatar
switch = stupid/pointless/gay/riceboy/retarded....you get the idea.
did your properly wire the solenoid/pressure switch? do you have the right ecu?
Old Dec 13, 2007 | 10:01 PM
jasony0630's Avatar
76.26.106.124
why a switch???? i know for a b16 swapped into a civic, there are 3 plugs on the b16 and only 2 on the car, the plug with the least wires on the b16 is the one for vtec...you wire it up correctly?
Old Dec 14, 2007 | 06:51 AM
Default Re: (jasony0630)
I GOT THE SI COMPUTER BUT NOT THE WIRING....WHAT ELSE DO I NEED
Old Dec 14, 2007 | 07:07 AM
ifIexplode's Avatar
You have to get the connectors For the VTEC solenoid and the VTEC pressure switch, Theyre comman connectors so just hit up the junk yard.
Then you have to Run wires from the Solenoid and Pressure switch to the Pin Outs on the ECU.
And you also have to wire the Knock sensor, The DX is not wired for that. Same connector as the VTEc pressure switch.
Here are the pinouts for OBDII
Old Dec 14, 2007 | 07:16 AM
Default Re: (ifIexplode)
YEAH THANKS MAN DATS WHAT IM GONNA DO.......
Old Dec 14, 2007 | 07:20 AM
ifIexplode's Avatar
Good Luck, Any More questions just ask,
Dont worry about the bozo's before my post.
b20_85
Apr 5, 2008 10:48 PM
NSfit
Dec 29, 2006 12:17 PM
ahthisguyhere
11
Apr 24, 2006 04:22 AM
Ak_ef9
17
Feb 16, 2006 03:34 AM
blackmagicCRX
20
Feb 14, 2005 10:37 AM
