When doing a core change for axles on .... please help...
Ok so i just got my swap and one of the axles are bad ... when i do the change what car am i telling them it came off of... a Del sol? or 99-00 Si?
its a jdm b16
its a jdm b16
did you say with or with out abs?
because they put them next to each other and the JDM one was shorter then the USDM
I dont think they asked me the question of ABS. But i would just tell them No ABS on that. Wait for someone else to chime in, im not positive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay »</TD></TR><TR><TD CLASS="quote">did you say with or with out abs?
because they put them next to each other and the JDM one was shorter then the USDM </TD></TR></TABLE>
thats not what he means, he means that he needs to know if he needs to tell them that he needs the axles for his yr car or for the motor that he swapped in... as to the op, my buddy put a b16 into his integra ls and he told them the axles for the car and not b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 »</TD></TR><TR><TD CLASS="quote">
thats not what he means, he means that he needs to know if he needs to tell them that he needs the axles for his yr car or for the motor that he swapped in... as to the op, my buddy put a b16 into his integra ls and he told them the axles for the car and not b16</TD></TR></TABLE>
what? no dude.... Im asking...
my JDM b16 axles are longer then usdm.... When i go to auto zone.. i walk in and what do i tell them....
"Hey I need a 99-00 drivers side axle" ? And will that work with my swap even tho its shorter?
I believe thats because B-series axles are interchangeable. But if your swapping a B-series into your civic or something, you'll need to ask for axles for the motor, not the car or else it will not work. Hes just trying to ask if needs to say Del sol B16 axles or 99-00 Si axles.
Is this right OP?
Is this right OP?
yeah... AND.... When they did pull out the del sol axles.... it was shorter... but it was with ABS... they didnt have any with out abs... i had to order that...
So....If i order the one with out abs.. will it be the same size as the JDM axle? or is it ok to be shorter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay »</TD></TR><TR><TD CLASS="quote">yeah... AND.... When they did pull out the del sol axles.... it was shorter... but it was with ABS... they didnt have any with out abs... i had to order that...
So....If i order the one with out abs.. will it be the same size as the JDM axle? or is it ok to be shorter?</TD></TR></TABLE>
Well it looks like you already saw the ABS one was shorter. So i'd go with the Non ABS. Theres only two choices here and one is knocked off, so the other should work
Good luck on that B16 swap and getting it running.
. Good luck on that B16 swap and getting it running.
thats what im sayong.... he asked if he needs the axle for the 99-00si (his car) or if he needs one for his B16 (from del sol) you both are saying the same as i did just wording it differently
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prism250 »</TD></TR><TR><TD CLASS="quote">
So long story short.... 99-00 SI non abs...? or del sol Non Abs?
The part number is differnt ... but what i dont get the motor is the same...
But thanks for the
but i have a feeling this swap is going to be a pain...and its not even day one
</TD></TR></TABLE>So long story short.... 99-00 SI non abs...? or del sol Non Abs?
But thanks for the
all of the following will work
99-00si
95-97 del sol vtec (dohc)
94-01 intergra(any) manual trans
your car doesn't have abs so you can use abs or non abs, it doesn't matter
I used part# 8000 and 8061 from Autozone, I forget which one is which side
hope this helps
99-00si
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">all of the following will work
99-00si
hope this helps
thanks a **** ton.... saved me alot of problems...
99-00si
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay »</TD></TR><TR><TD CLASS="quote">will that matter any?</TD></TR></TABLE>
they're all the same. if you like del sol's more then ask for those... if you like civics, ask for those.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay »</TD></TR><TR><TD CLASS="quote">Ok so i just got my swap and one of the axles are bad</TD></TR></TABLE>
are you sure they compared your axle to the correct side, because there isn't any jdm/usdm difference?
well the guy said the one i have is like 24 1/4 and all they sold up to was 22 1/4
I called auto zone and they told me they had a integra with abs axle in stock so im going to pick that up tomarrow when they open... i hope it works...
does it matter that its not a GSR
99-00si
hope this helps
See this is what i what i was trying to say, how B-series axles are interchangeable, so all of the part numbers should have been the same essentially and not matter which one to go with.
99-00si
hope this helps
I didnt know that but now i do.... and someone was saying ABS doesnt matter as well...
So now i have to try to find out why my axle was shorter.... The guy told me mine was driver side that was bad... maybe he was wrong
im off for the night... so thanks people for your help... ill check up on this tomarrow befor i go to auto zone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustHere4ADay »</TD></TR><TR><TD CLASS="quote">I didnt know that but now i do.... and someone was saying ABS doesnt matter as well...
ABS doesn't matter. It's just the sensor gear on the outer joint - you can leave it on without trouble, or pry it off if you're really that worried about it.
