vtec solenoid problems
Old Dec 13, 2007 | 04:32 PM
zcarkid's Avatar
Default vtec solenoid problems
i had my vtec solenoid go out, i replaced it, and it still doesnt work, same problems as before, when it gets to 5500 it does nothing and about 6k the check engine light comes on, resets by shutting the car off and turning it back on, any suggestions?
Old Dec 13, 2007 | 06:03 PM
z6hatchboy's Avatar
Check the cel first, if you dont know how there is a post at the top of the civic/del sol (1992-2000) section where this is posted, it help a lot . Sounds like it might be the vtec pressure switch though, good luck!
Old Dec 13, 2007 | 06:12 PM
96teggylsse's Avatar
Default Re: vtec solenoid problems (zcarkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcarkid &raquo;</TD></TR><TR><TD CLASS="quote">i had my vtec solenoid go out, i replaced it, and it still doesnt work, same problems as before, when it gets to 5500 it does nothing and about 6k the check engine light comes on, resets by shutting the car off and turning it back on, any suggestions?</TD></TR></TABLE>
im pretty sure its not the vtec solenoid then.... check your codes!!!
Old Dec 17, 2007 | 05:20 PM
zcarkid's Avatar
ok, sorry i took so long to get back, i had a 21 on my old vtec solenoid and after i replaced it, ive still got a 21, and the same problems as before, did i buy a bad solenoid or could there be something else wrong?
Old Dec 17, 2007 | 05:34 PM
z6hatchboy's Avatar
I dont know how often that happens, lol. did you notice any build up of anything when you took it out, sludge or anything? Im still guessing the pressure switch though.
Old Dec 17, 2007 | 07:41 PM
zcarkid's Avatar
Default Re: (z6hatchboy)
nope, except for oil they both looked clean, nothing that looked suspicious
Old Dec 23, 2007 | 08:15 PM
zcarkid's Avatar
Default Re: (zcarkid)
*bump* any suggestions?
Old Dec 23, 2007 | 08:17 PM
z6hatchboy's Avatar
Check the wiring for shorts, has your ecu been worked, the pin may have come out.
wicked_b16eg's Avatar
its got to be the presure switch
Old Dec 23, 2007 | 08:28 PM
Hittnthebz's Avatar
Did you reset the ecu after replacement? You may be running in limp mode.
Old Dec 25, 2007 | 09:31 PM
zcarkid's Avatar
no, i did not reset it and did not think to look for shorts, i wont have time tomorrow but ill check thursday
Old Dec 25, 2007 | 09:45 PM
blueEM1's Avatar
make sure ur oil is full to, while ur at it
EGThang
18
Jun 6, 2008 03:26 PM
xtreme-customz
18
Dec 1, 2005 07:51 PM
LSegHatchy
Jun 6, 2005 08:04 PM
kriptik
Oct 11, 2004 02:24 PM
FleXingMyEK
Jun 2, 2003 06:02 PM
