DA front sway bar?(did search)
Old Jun 27, 2002 | 08:30 AM
JalopySiR's Avatar
Default DA front sway bar?(did search)
Hello, I realize this is a simpler question, and had hoped to find an answer through searching, but alas, no luck. Could someone please tell me if a non-VTEC DA integra front sway bar is the same as a 91 CRX Si front sway bar? If it is indeed larger, it will bolt in correct?
Thanks, Alex
Old Jun 27, 2002 | 10:39 AM
Home Skillet's Avatar
Default Re: DA front sway bar?(did search) (JalopySiR)
i believe its a different chassis. but thats from what ive heard, nothing documented.
Old Jun 27, 2002 | 11:41 AM
JalopySiR's Avatar
Default Re: DA front sway bar?(did search) (Home Skillet)
ok..... anyone else?
Old Jun 28, 2002 | 05:54 PM
seekerONE's Avatar
not the same size...thicker and yes it bolts straight up...need brackets from teg also...BTW don't bother with the rear bar...same as si
Old Jun 29, 2002 | 01:53 AM
dlric's Avatar
yep indeed it is bigger. i have a '91 crx si and a DA front sway sittin in my basement and the crx si front sway is like a toothpick compared to the DA.
i dont need the sway bar anymore..im in mass..hit me up if u need it..would be glad to get rid of it.
bluestd
Aug 8, 2009 08:49 AM
chadmasterc
Nov 24, 2003 11:21 AM
ShagginJet
Aug 27, 2003 10:00 AM
NTGR8D
Mar 13, 2003 11:13 PM
