Suspension & Brakes Theory, alignment, spring rates....
Suspension Guru's put your .02
Old Dec 13, 2007 | 03:40 PM
Myh4tch's Avatar
Default Suspension Guru's put your .02
car: EG
motor: h22
I've been doing a lot of research on my new suspension setup,
and i've come down to the spring rates now on my ground controls.
I've search around a lot and read what other people are running and
have also been reading about the difference in higher rates in the front compared
to the back as well vice versa.
I want the car to be pretty well rounded, its mainly a fun DD, taken to the track and also spiritly driven on twisties.
what i've come down to is 425F/450R, add a little oversteer to counter the understeer and a bit higher rating in the back for the *** drag when launching at
the track.
What do yall think of those rates? Pros and Cons?
Old Dec 14, 2007 | 06:56 PM
Myh4tch's Avatar
any opinions?
Old Dec 14, 2007 | 07:08 PM
PIC Performance's Avatar
Default Re: Suspension Guru's put your .02 (Myh4tch)
I think those rates are a little much for stock shocks.
Old Dec 15, 2007 | 03:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Suspension Guru's put your .02 (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">I think those rates are a little much for stock shocks.</TD></TR></TABLE>
More like WAY too much for stock shocks.
But I didn't see where the OP said he was running stock shocks. I should certainly hope not with an H22 engine in a Civic.
Old Dec 16, 2007 | 01:29 PM
Myh4tch's Avatar
sorry should of wrote in there koni yellows
Old Dec 16, 2007 | 02:43 PM
Default Re: Suspension Guru's put your .02 (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
But I didn't see where the OP said he was running stock shocks.</TD></TR></TABLE>
Exactly. OP needed to specify.
Old Dec 24, 2007 | 09:47 AM
Myh4tch's Avatar
ok to clarify it would be bought from ground control obviously with custom rates (425F/450R) and koni yellow shocks.
now opinions? I want to know if it is a bad idea to have it stiffer in the rear, should I switch that up to 450F/425R or what?
panchlow
Suspension & Brakes
10
Aug 4, 2010 12:29 PM
stivic
Suspension & Brakes
Jan 21, 2007 06:20 PM
Flava
Suspension & Brakes
19
May 18, 2006 11:02 AM
servion
Suspension & Brakes
Jan 12, 2005 08:25 PM
SilverDc2
Jun 22, 2003 04:07 PM
