timing belt noise
Old Dec 13, 2007 | 02:48 PM
adamrich33's Avatar
Default timing belt noise
i have been needing to replace the timing belt tensioner for a few months now on my wifes 97 hatch, it has the d16y8 motor, i also put a new gates racing timing belt on it (the blue one) and it is making some noise. its not the whining noise like when there to tight but almost a squeking sound, its pretty cold here in ky right now is it possible the belt just needs to warm up and break in maybe. i have never installed a gates racing belt before and just need to know if there a little noisey
thanks
Old Dec 13, 2007 | 02:54 PM
King V's Avatar
Default Re: timing belt noise (adamrich33)
Could either be too loose or when you put the new belt on the water pump finally decided to die from the "fresh" belt pressure.
Old Dec 13, 2007 | 04:53 PM
adamrich33's Avatar
Default Re: timing belt noise (King V)
i was wandering the same thing about the water pump. it doesnt seem to have much play in it with the tension off but im not sure if there is some minimal play to it if you wiggle the pump sprocket up and down
Old Dec 14, 2007 | 04:02 AM
adamrich33's Avatar
ttt
Old Dec 14, 2007 | 09:02 AM
King V's Avatar
No wiggle at all. Should be completely tight. Wiggle=bad
Psycho719
Sep 14, 2011 04:28 AM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
Drew96EJ
Oct 30, 2003 01:48 PM
imports
Jun 25, 2003 11:44 AM
obd2gsr
Dec 21, 2002 08:53 PM
