282 mm Rotors + Spoon twinblock 4 pots + Buddyclub p1s 15x6.5 42 offset.... Will this work?
Hey guys
basically as title asks, is there a minimum wheel size that is needed for 282mm rotors and Spoon 4 pot calipers? Should they be find under my buddyclub P1 15 x 6.5 42 offset. Or will they not clear? if so anyone know what size spacers i will need? and will i need longer wheel studs?
Also will the factory brake lines fit the spoon calipers? or do i need some specific fittings made up?
Lyle
Lyle
