Suspension & Brakes Theory, alignment, spring rates....
ek/ del sol fit???
Old Dec 13, 2007 | 11:48 AM
BoostnEK6206's Avatar
Default ek/ del sol fit???
would skunk2 rear lower control arms and rear lower strut bar for a del sol fit on a 96 hatch??
Old Dec 13, 2007 | 12:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
no, different length control arms. you'd have nasty camber and trailing arm bushing binding problems.
Old Dec 13, 2007 | 12:19 PM
Default Re: (PatrickGSR94)
thanks! any suggestions on what to get?
Old Dec 13, 2007 | 12:27 PM
Community Builder
control arms for a 96-00 Civic... or just stick to stock, no need for aftermarket really.
Old Dec 13, 2007 | 12:32 PM
why is it pointless to get aftermarket ones? you d think that if they make em they make em for a reason?
Old Dec 13, 2007 | 12:52 PM
Community Builder
Default Re: (BoostnEK6206)
They're mostly for bling and looks. Yea some of them save a couple of pounds, but it's really not going to make much a difference.
If your car didn't originally come with a sway bar and you want to add one, aftermarket arms might cost less than new OEM arms with sway bar provisions, but there are only a couple of after market ones that actually have the sway bar holes in the correct location.
Old Dec 13, 2007 | 01:43 PM
ya but wudnt it make a difference if u had both instead of jus one
Old Dec 14, 2007 | 04:38 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostnEK6206 &raquo;</TD></TR><TR><TD CLASS="quote">ya but wudnt it make a difference if u had both instead of jus one</TD></TR></TABLE>
you mean aftermarket LCA's and a rear lower tie bar? Nah man those are pretty well independent of each other.
itsmejto
Aug 11, 2008 04:40 PM
VTEC IS UR BEST FRIEND
Suspension & Brakes
Mar 10, 2008 12:55 PM
xkwzt21
Suspension & Brakes
Aug 14, 2005 04:39 PM
CRX-RX
Apr 8, 2004 01:48 PM
phantom_sol
Apr 6, 2003 05:11 PM
