FS: B series & D series parts (ECU, P72, CRX, IACV, TB, Z6, VOLK, cams, etc...)
Update 10-05-09
Need to clean my garage so here’s the list of parts. All parts are for SOHC DOHC Civic/CRX
Parts are LOCATED at my parents house in SAN DIEGO zip 91911
Pick Up ONLY because I go to college in LA and my twin brother is in charge but he's willing to ship out with additional shipping cost unless notice.
Shipping Method: I ship by USPS or FEDEX depending on the cost (cheaper is better!!!)
Some small sensor and plugs I will no longer ship alone because its not worth the $$ unless you buy multiple items. Reason: I once sold a injector plug for $13 and UPS (USPS was closed) charge me $10.01 for ground shipping for a small box weight less than 1 lbs.
The item listed below is what I have for sale and if you do see something on the picture that's not listed, it means that the item has been sold.
-CRX Si flywheel with bolts (minor rust) - $20
-92-95 D-series power steering pump + bracket - $20
-(3) 92-95 Automatic Hydro VSS - $20 each
-OBD1 ECU connector - $10
-CRX front speaker cover (minor crack on one) - $10 pair
-CRX front speaker mounting bracket - $10 pair
-D16A6 CRX Si crank pulley - $20
-JDM D15B VTEC crank pulley (chipped on A/C side) - $15
-D16A6 dirver side motor mount with bracket - $10
-OBD0 D-series alternator w/o pulley (works but it makes a winning noise)- $5
NO- PICTURE
-D-series transmission cable bracket - $5
-92-95 D16Z6 Alternator Belt (like new condition) - $5
-B-series alternator (Type-R swap but tested bad) - $10
The picture below is what your getting. Please feel free to ask any question....
SOLD
Itslogz – AEM Cam Gear Bambbrose – OBD0 Injectors Krisfnbs – 2 Hydro VSS harmonator84 – PR4 ECU
Mr_CRX – DA VSS 24TEN – GSR T cover, D16 IM ekillah – OBD1 IACV RSZero1 – PR4 ECU
ca-rs – HF CAT JayGee625 – OBD0 IACV Fonkernuckle – VTEC solenoid mgs1098 – Hydro VSS
slowlittlewhitey – OBD1 IACV b18vtecboi – D Mount FG2 chilotz – OBD1 IACV Obuhmyuh – IACV
Blazinearth – ITR IM SawBoss – P72 PS Pump EJ2-Fluffy – radio, MAP sensor dkboyny11 – ITR CAMS
agustin – Jump Harness stellhornata – cable VSS 95singlecamvtec – MSD cap 818blue818 - FITV
ptftw - Distributor myfirstdc2 – OBD1 injectors eg-perk – ECU connector Navy_CRX – AEM fuel rail
88civic - vtec solenoid triphop718 – ECU connector ==Catfish== - B-series motor mount bracket
srt4pilot – D series motor mount bracket Reza^ - OBDI injectors Group Tenacity – PR3 A/C bracket
EGR95 – B16 Intake Manifold socalJDMer – OBDII injectors d_EG COUPE – traded VSS with ITR LCA
MonKK – OBD0 injectors dpetro1 – IACV boo5tedteg94 - OBD1 injector platinumg2 – B heat shield
EFin' Kyle – CRX R1 coilover Thegoatc – harness plugs Littlekeel – OBD1 engine harness 91(si)hatchey – ECU plugs
Gsrswapdcivic – VSS eggsi619 – B heat shield dubs97integ - Si Harness Spunkster - DA 1/2 Shaft XxDrUnKnMuNkxX - OBD1 IACV
BOUGHT
88crxsir – CRX door skirt bluebird – D15 Vtec Nerologic – Many things Mr_CRX – Many things
Outsane – CRX corner light, door panel LoSt is BlaCk D15 Timing cover 24TEN – Si Seats
DC2SIR-G – GSR transmission Alanicious – linkage Trimugenhatch – B16 long block Del Sol SiR – USDM P30 ECU
Oinojo – B16 swap mccoy1178 – P30 IM Your Name – BBK TB SlowSOHC-T – NGK wire
1990CRXSIJDMEF8 – Craftsman tool box eg2jr – CRX B pipe grip200kg – TSW fourthgenhatchB17 – Bunch of SOHC
iownahatchback – D16Z6 Intake Manifold JDM_JNKY – B16 cams f@sth@tch89 - P28 ECU em1loc – P61 ECU
mabbiker – Speaker plate + AEM silentdaredevil2 – OBDI harness skavenger*ef9 – CRX head light + H&R spring w/ strut
Ldo – CRX T-bar & ½ shaft frank_el_tanke – JDM wire harness + B16 IM #1DA2HATE – B-series TB
snowboardgeek1 – EX cluster + spoon mirror ThatGreenGsr – 92-93 GSR CAMs Radim – HKS short ram
LS94tegra – D16Z6 Dizzy da9leo – DA Cat
NO- PICTURE
SOLD
BOUGHT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">BUMP for you sir...</TD></TR></TABLE>
Thanks man
Thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A- »</TD></TR><TR><TD CLASS="quote">
Thanks man!!!!
</TD></TR></TABLE>Thanks man!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989rexsi »</TD></TR><TR><TD CLASS="quote">where did that zc trans go i finally got cash... </TD></TR></TABLE>
I traded with Mr_CRX and he has it for sale.
