what wheel does power go to?
Old Dec 13, 2007 | 06:17 AM
ityab0y's Avatar
Default what wheel does power go to?
Hello, in the case of a front wheel drive civic with no differential, what wheel does the power go to. front left or front right?
Old Dec 13, 2007 | 07:21 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what wheel does power go to? (ityab0y)
Both front wheels. And all modern cars use a differential. When you say "without a differential", you're probably thinking of a limited-slip differential, which is a specific kind that prevents opposite wheels from spinning too much. All cars use a differential, but not all cars have a limited-slip differential.
Click on the photo for more details.
Old Dec 15, 2007 | 06:09 AM
yoson718's Avatar
Default Re: what wheel does power go to? (nsxtasy)
power wise. from what i think i know,i say think cause im not 100% sure but more power is distributed to the right front wheel.
Old Dec 15, 2007 | 10:06 AM
cjames235's Avatar
Default Re: what wheel does power go to? (yoson718)
as nsxtasy was saying, both front wheels pull just not at the same time (in most cases) with an open differential
open diff (what you are describing): power goes to whatever wheel has the least restriction, left or right
limisted slip diff: power is distributed through both wheels at the same time
allmotorh2b
Dec 21, 2008 08:53 AM
gerhard
Acura TSX
May 18, 2006 02:09 PM
mkell
Honda S2000
Feb 28, 2005 05:14 PM
whoneedzvtec
Dec 12, 2004 02:42 PM
onesojourner
May 27, 2002 06:22 PM
