Hondata s300 Nitrus wiring help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">I'd really ask yourself; If you using S300; and nitrous..I'd think you'd know something about wiring and relays...
true about that
</TD></TR></TABLE>true about that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">Hows he using s300 in his 94 accord...
whats wrong with that? Last i knew S300 supported H series engines
</TD></TR></TABLE>whats wrong with that? Last i knew S300 supported H series engines
What ecu is he using in a 94 accord..converting his car to be able to run on a chipped p28 is alot more complex then wiring up simple nitrous power and ground wires to the ECU pins; sounds like he has more of a problem then you think
you can plug a p28 into a 94 accord and drive it. no wiring involved.
more or less you are going to have an arming switch which tells the hondata that your ready to spray. (input)
from the ecu to a relay is the how the solenoid starts spraying (the output)
so another words you have to have the input on so the computer knows you want to spray...then in the software you tell it how you want it to spray (say above 3500 rpm and 90% throttle)
when the switch is on, and your above those settings, the nitrous will spray. pretty simple.
Well its on my civic...***
any ways i was just confuesed on how the realy worked.....And isnt the point of the sight if i have a question is to ask...
Ps the s300 runs the accord just fine along with delsol
Thanks i should have it up.. and Runnin my high 11S
crxhftosi
Nov 19, 2004 08:51 AM
