Koni/GC or Keep Eibach Sportline
I currently have Eibach Sportlines on my SiR. But as we all know, the driver side is lower than passenger. Driver less than 1 finergap, Passenger around 2+ gap. I don't like it. Im thinkin of koni/gc 400f/350r. I want the car to have no gap, or a tucking. Am I sacrificing too much of suspension travel? Would I need tophats? And also if I want it that low, would I need to remove the fender lining? Thanks, sorry for too much questions.
either way you look at it the koni/gc setup is superior...AND adjustable.
if you think you do not have enough suspension travel, if you think you need to re-adjust height, if you are taking a long trip and want a higher/more comfortable ride, if you even want different spring rates, which suspension would you want?
yea I know that the koni/gc is better but im concerned about hitting bumpstop every bump on the road.. Top hats recommended for 0 gap or little tucking? Would i need to remove the fender lining/splash shield?
dornon13
Suspension & Brakes
26
Nov 14, 2006 06:42 PM
Philbert
Aug 30, 2001 09:46 PM
