building a d16z6
Old Dec 12, 2007 | 04:39 PM
tensecpass's Avatar
Default building a d16z6
im getting ready to buy a 1994 civic ex. i wanna build the motor thats in it which i believe is a d16z6, but i dont want to turbo it. any ideas?
Old Dec 12, 2007 | 04:41 PM
WhiteOnRice's Avatar
It is a d16z6. That being said, why don't you want to boost it?
Old Dec 12, 2007 | 04:43 PM
tensecpass's Avatar
Default Re: (WhiteOnRice)
because its a lot of work, if i did go the turbo route what all would i have to do b4 i put a turbo on?
Old Dec 12, 2007 | 04:55 PM
Toroke's Avatar
Default Re: (tensecpass)
Sleeving isn't necessary. It's rather expensive. You'd need new rods, pistons, bearings, machine work done, new oil pump/water pump/timing belt, and... that should be about it...
Old Dec 12, 2007 | 04:58 PM
tensecpass's Avatar
Default Re: (Toroke)
sleeving?
Old Dec 12, 2007 | 05:13 PM
tensecpass's Avatar
and also. if i did boost it, would i need a turbo timer,blow off valve. new cams. ect
Old Dec 12, 2007 | 05:22 PM
project 98ek's Avatar
best wey to make a single head go fast is mill the head (shave the head a couple mm) so that u get more compression. slap on some bolt ons n tune it n ur ready to go!
ow n u should know how to race ur car. when it comes to single heads its all about how u run ur car.
Old Dec 12, 2007 | 05:26 PM
tensecpass's Avatar
Default Re: (project 98ek)
yeah, a lot of people are saying to go with n/a. iv never been in a real "race" but have done a lot of driving at high speeds and am pretty good with a clutch(not tryin to sound cocky cause i know im no where close to good)
Old Dec 12, 2007 | 05:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tensecpass &raquo;</TD></TR><TR><TD CLASS="quote">and also. if i did boost it, would i need a turbo timer,blow off valve. new cams. ect</TD></TR></TABLE>
Just buy a used kit. They are everywhere on here.
Old Dec 12, 2007 | 05:44 PM
dkid15's Avatar
Default Re: building a d16z6 (tensecpass)
start off with I/H/E and see where it takes you.
Old Dec 13, 2007 | 04:58 PM
tensecpass's Avatar
Default Re: building a d16z6 (dkid15)
from what i have read i/h/e wont help that much, but i dont want to have to put all new internels in then spend money on a turbo, is it possable to just buy the turbo kit or will i have to get new internals? what about a turbo timer?
Old Dec 13, 2007 | 05:07 PM
90hatchblack's Avatar
man all u have to do is buy a tubo kit and some sort of engine management and some dsm injectors and your golden
all this talk about internals is nonsense unless your gonna boost 20psi or sumthin u should be fine at 8-10 psi on stock internals
Old Dec 13, 2007 | 05:08 PM
jasony0630's Avatar
76.26.106.124
hey, feel bad for me...i had a d16y8 automatic in my 99 ex, but its in the shop right now getting a b16a3 with a 5 speed conversion...and getting boosted....
Old Dec 13, 2007 | 05:18 PM
tensecpass's Avatar
Default Re: building a d16z6 (90hatchblack)
haha, iight, that anwsers my question, should i buy an exhust kit befor i buy a turbo kit?
z6hatchboy's Avatar
Im doing a vitara setup hopefully push 20 psi, on my z6, should be fun. Get boosted, its not harder than n/a if you have the money, it just a matter of turring wrenchs if you do it right
Old Dec 13, 2007 | 05:28 PM
tensecpass's Avatar
Default Re: (z6hatchboy)
yeah, im not worried about the work, i have rebuild a few ford engines for my truck and **** like that, but if im runnin 6-8 psi how much whp u reckon ill be pushin?
Old Dec 13, 2007 | 06:16 PM
Prism250's Avatar
Dont try to build your D16 all motor. If your going to do anything, then boost it. Theres no sense in building the engine if your not looking for alot of power. No need to talk about internals or sleeving or cams. But it is a nice upgrade to get the zex cam . But seriously you can push 200WHP on a decent turbo set up on a D16 without having to do any real work to motor. You wont see those numbers with all motor. I/H/E is almost pointless, you should save that little bit of money and buy yourself a nice used turbo setup, they usually go for cheap and you should'nt have too much trouble finding one. Lastly if your worried about reliability do it right the first time and get a good tune and you wont have anything to worry about.
Good luck with your decision
Old Dec 16, 2007 | 05:30 AM
mercutio_07's Avatar
Default Re: building a d16z6 (Prism250)
X2
Old Dec 16, 2007 | 06:28 AM
92ehatch's Avatar
Default Re: building a d16z6 (mercutio_07)
im going with a 75.5mm ycp vitara piston, tuner toys h beam rods, arp headstuds and a t3 turbo.
i plan to push 14 psi on my setup.
turbo is about all you can do to a z6 that is cost effective, NA is going to be expensive and not going to yield very high results.
Old Dec 16, 2007 | 06:46 AM
Del Sex's Avatar
Default Re: building a d16z6 (92ehatch)
If you are just looking for a fun daily setup, I wouldn't go boost, at least until you know more about it. Don't take it the wrong way - just my opinion. Boost can be great if you know what you're doing with it, and by knowing, you'll be faster and won't have nearly as a high of a chance of blowing it up lol.
I think if you have a D16z6, you should get I/H/E, new clutch with Fidanza flywheel, and a 4.9 Final Drive from http://www.exospeed.com. If you want more, get the Stage 2 cam from http://www.exospeed.com. They are great to deal with and everything I just mentioned won't make your car FAST, but a blast to drive around. If you're trying to race a lot, that's not the setup for you. But that thing will be peppy out of the hole.
Old Dec 18, 2007 | 03:45 PM
tensecpass's Avatar
Default Re: building a d16z6 (Del Sex)
yeah, because i dont wanna put something on my daily driver unless i know a lot about it, i did find some 11.25:1 high compression pistions made by like wisco(spell check) and it was a full set for about $550. so i was thinking about gettin a set of those because someone told me if i do n/a then i should invest in higher compression pistons...any ideas?
Old Dec 18, 2007 | 03:53 PM
luvmihatch's Avatar
just turbo it run low boost and dont get boost happy. then u will have a fun car to drive that will be a hell of alot cheaper more hp and u will have alot more fun.
Old Dec 18, 2007 | 04:20 PM
Del Sex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tensecpass &raquo;</TD></TR><TR><TD CLASS="quote">yeah, because i dont wanna put something on my daily driver unless i know a lot about it, i did find some 11.25:1 high compression pistions made by like wisco(spell check) and it was a full set for about $550. so i was thinking about gettin a set of those because someone told me if i do n/a then i should invest in higher compression pistons...any ideas?</TD></TR></TABLE>
No no no man. Save yourself some money. If you want higher compression pistons... get some P29's/PM7's .. they are Honda OEM pistons out of the DOHC D16A1 motor.
I did some research and one of the compression calculators said that the compression would be around 13.6:1 .. which sounds high. A buddy of mine is running a Z6 with P29's and is tuned on pump gas which would make 13.6:1 VERY hard to believe .. any ideas anyone?
But you can get some OEM parts that will do the job if you are trying to stay N/A. Trans work and head work will be your go to things IMO though.
Old Dec 18, 2007 | 04:33 PM
tensecpass's Avatar
ill look into that, i just dont wanna turbo it when i dont know that much about it..and id really like to keep it n/a
Old Dec 18, 2007 | 04:40 PM
luvmihatch's Avatar
yeah f*** all motor too expensive with out the motor gains.. bc unles you know how to rebuild motors then its going to be alot more then 550 bucks to put new pistons.. u need all new gaskets from the head gasket to the oil pan.. then u may need head studs.. reccomended.. if u wanna do it rite. so im just saying make sure u do your resurch before you go neck deep in something you have no idea about.. just my 2 cents from some one thats been in the game a long time..
