1990 EF *Street/Race Project* LS V, Turbo, Nitrous, Roller Rocker CANADA
Just posting my setup.
1990 Ef Civic
- Soon to be fresh Milano Red paintjob
- JDM front bumper
- Carbon JDM style hood for USDM front end
Motor
1st Gen LS Block 82mm (Thanks to Canadian Cylinder Head Technologies)
- Lightened and balanced crank
- Darton sleeves
- Wiseco 9.7:1 Pistons
- Eagle H Beams
- King Race bearings
- OEM GSR oil & water pumps
- CTR Crank pulley
- Golden Eagle Sandwich Plate
- ARP Studs everywhere
- Cometic 82mm Head Gasket
1st Gen B16 Head (assembled by Ajax Engines.)
- Custom Square Ported Head (Thanks to Rev N High Automotive in Ajax)
- Professional Products/AEBS Intake Manifold also Square ported and matched to Head
- Magnus Fabrication Phenolic intake manifold gasket also Sqaure ported and matched to head and int. manifold
- Omni Springs and Retainers
- Custom brass valve guides
- Ceramic coated OEM valves (Thanks to Atlantic Heat Treating in Ajax)
- Ferrea Second Gen Roller Rockers and VTEC Killer Cams
- STR Adjustable Cam Gears
- Dual Feed Mr. Gasket Fuel Rail
- RC 750cc Injectors (Wanting to upgrade to 1000cc)
- AEM Universal Fuel Psi Reg
- -6 Stainless Braided Line for all fuel Feeds and Returns
- Professional Products High Flow fuel filter
- Professional Products 68mm Throttle Body
- JDM Type R Valve Cover
- Universal Spinners Custom PCV Catch Can
ZEX Dry Nitrous Kit
- 55hp Jets
- Purge Kit
Yonaka Aluminum Rad with FAL Slim fan
Precision PT67/76 S Turbo T3 Flange
- -4 Feed, -10 Return
- Custom 3-4" Stainless down pipe
- Full 4" Aluminized Exhaust
- 4" DNA Muffler (for CSCS class purposes)
Ram Horn Style Manifold
TurboSmart Wastegate and BOV
Full 3" Aluminum charge pipes
Intercooler with Custom End Tanks (Back Door Style)
MSD 6AL
MSD 3 Step
MSD Blaster Coil
MSD Cap
MSD Spark Plug Wires with NGK #8 Plugs
Stock LS Tranny
- Competition Clutches Stage 5 Unsprung Hub with upgraded Pressure Plate
- Custom Drive Shafts
Bogart Flystar Slicks and Skinnies
-M/T 24.5 x 8 x 13
-M/T 22 x 3 x 15
P.I.C Drag Spec Full Coilovers
Blox Lower Control Arms
KVR Cross Drilled rotors
Full Chromoly Cage
Relocated Battery with Custom Aluminum battery tray
Everything is being fabricated over the winter
Lot of time and money has already been spent and more needs to be spent
Im only 19 years old and trying to live like im 19 and build this car too
Looking to make 500+ on 20 psi or so, 550+ on the spray.
Special Thanx Goes Out to MEANIE Racing, Rev N High Automotive, Ajax Engines, the boys @ Teknotik, Universal Spinners and TDC Automotive.
Thanx.
Modified by philbertef9 at 1:50 PM 12/13/2007
Modified by philbertef9 at 1:51 PM 12/13/2007
1990 Ef Civic
- JDM front bumper
Motor
- Darton sleeves
- Eagle H Beams
- CTR Crank pulley
ZEX Dry Nitrous Kit
- 55hp Jets
- Purge Kit
MSD 6AL
MSD 3 Step
MSD Blaster Coil
MSD Cap
Stock LS Tranny
-M/T 24.5 x 8 x 13
-M/T 22 x 3 x 15
Full Chromoly Cage
Thanx.
nice build....i wouldnt trust eagles over 600whp, maybe with a switch to some other rods, and bigger injectors you can make some big power..
hope everything works out for you, looks like your going to make some nice power
no this setup was never in a da, are you talking about the white one? That was just a stock on stock ls vtec.
i know the setup is good for around 650whp, but for the time being whatever 20 psi brings me ill be happy with.
bad setup.......i like it.
2 things, 750's arent gonna do it unless you run more than 4, 1000's would be better, and the ctr pulley, loose it fir an ATI or fluidampr. your oil pump will thank you for it.
gl
gl
i dont get how thats possible? whats wrong with a brand new ctr pulley, from honda i might add, that its gonna kill a gsr oil pump? Ive read that a few times now but i dont understand why or how, can someone explain this?
