2002 civic EX manual transmission problem
Old Dec 12, 2007 | 02:16 PM
uber.spaced's Avatar
Default 2002 civic EX manual transmission problem
2 days ago, I noticed the transmission was a little sluggish going into forth; I had to pull on the thing harder than usual.
I started noticing more issues now, down shifting from 4th to 3rd requires one hell of a push (Yes, I'm pushing the clutch all the way down). When I move the stick to either side before directly putting it in gear, the transmission willingly goes into gear.
Anybody know what type of problem this is or how much it costs to fix?
Old Dec 12, 2007 | 10:33 PM
Twixle's Avatar
ate my pixel
Default Re: 2002 civic EX manual transmission problem (uber.spaced)
Try double-clutching when you shift. If that fixes the problem, you need to change your syncros. Doing it yourself requires some tools and quite a bit of time, and you should have some know-how. A shop is going to cost you a pretty penny to fix it, several hundred dollars at least.
Old Dec 13, 2007 | 09:36 PM
Justin4's Avatar
didn't that year accord have a recall on their trannies?
gotofbi
May 30, 2011 06:17 PM
DJ4Jesus77
Honda Civic (2001 - 2005)
10
Oct 8, 2010 08:57 PM
JDM-EJ1
Feb 28, 2005 08:50 PM
deejaycherub
Oct 27, 2004 03:19 PM
