stripped flywheel bolts
Old Dec 12, 2007 | 11:30 AM
got_no_sol's Avatar
Default stripped flywheel bolts
anyone know how i could get these out they are extremly tight so... any advice is greatly apreciated. thank
Old Dec 12, 2007 | 12:28 PM
chicows18's Avatar
Default Re: stripped flywheel bolts (got_no_sol)
WD40 is as best as its going to get. Good luck.
Old Dec 15, 2007 | 07:57 PM
z6hatchboy's Avatar
Go to sears and get their bolt removers (not the name of them, but tell them what the problem is, because they're for stripped bolts), some WD-40 and a impact gun, and give it your best.
Old Dec 15, 2007 | 08:21 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Go to sears and get their bolt removers (not the name of them, but tell them what the problem is, because they're for stripped bolts), some WD-40 and a impact gun, and give it your best.</TD></TR></TABLE>turbos
Old Dec 15, 2007 | 08:59 PM
fmrprojects's Avatar
Default Re: (Throwdown)
good luck, but i think the strip bolt remover works on 6 point bolts/nuts
Old Dec 15, 2007 | 11:03 PM
Frickr's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">good luck, but i think the strip bolt remover works on 6 point bolts/nuts</TD></TR></TABLE>
it just depends on what ones you get, they have to major types out, one where you drill a hole into the end of the bolt say if you broke the head off or something, and you stick this twisted, almost drillbit looking thing that flairs out into the hole you drilled. those work probably the best, but you have to be careful when your drilling. Irwin makes some great ones. and also they have some that go over the head of the bolt and grab the outside of the bolt and turn it that way. those work great unless if the bolt is heavily stripped, or you break the head. just ask the people at the parts store you need a bolt extractor, it will be back with the endwrenchs or drillbits.
Old Dec 16, 2007 | 12:21 AM
ke98248's Avatar
Default Re: stripped flywheel bolts (chicows18)
Not really, KROIL is the best, and then PB Blaster is for the cheapos.
Old Dec 16, 2007 | 04:46 AM
blackeg's Avatar
Default Re: stripped flywheel bolts (ke98248)
heat. heat up the flywheel around the bolt. if its not stripped too bad use an impact gun. make sure you have the the crank secured somehow so its not gonna rotate the motor.
you could always as a last last resort drill and tap the bolt so you can thread a bolt into there and get it out that way. ive done it once on a bolt but it was a super last resort
Old Dec 16, 2007 | 05:16 AM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: stripped flywheel bolts (blackeg)
My friend had that problem, he bought the bolt stripper socket from sears and than let PB blaster penetrate on the bolt for awhile and than used a impact gun to take the stripped flywheel bolt out.. If that doesnt work, your best bet is to drill it out or heat it up.. Good luck though.
Old Dec 28, 2007 | 12:26 PM
got_no_sol's Avatar
Old Dec 28, 2007 | 12:29 PM
got_no_sol's Avatar
thanks for the help, but the bolt removers failed and i ended up putting a coulple hours in on the diegrinder lol, but anyway they are off , so on with more work, and again thanks for all the help.
DC2 Mang
Jun 1, 2023 08:41 AM
Prudz_lude
Feb 23, 2008 10:06 PM
igo4bmx
Jul 8, 2007 12:10 PM
DC4_MADMAN
Suspension & Brakes
Sep 7, 2005 09:22 AM
iLUVmyACCORD
Dec 30, 2004 06:11 PM
