Clicking sound from H22 after 3rd gear pull. WTF?
Old Dec 12, 2007 | 03:59 AM
jetlude's Avatar
Default Clicking sound from H22 after 3rd gear pull. WTF?
Any ideas what got messed up? Its a clicking sound (not too heavy) that is only heard at at idle as revs increase it goes away. Sounds like the top half of engine.
Old Dec 12, 2007 | 04:10 AM
Mikey3000's Avatar
Default Re: Clicking sound from H22 after 3rd gear pull. WTF? (jetlude)
it could be anything. try to narrow it down more, like left side, right side, back, etc.
Old Dec 12, 2007 | 05:06 AM
HarfordCTR's Avatar
Default Re: Clicking sound from H22 after 3rd gear pull. WTF? (Mikey3000)
Could be an injector
Old Dec 12, 2007 | 05:36 AM
jetlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">it could be anything. try to narrow it down more, like left side, right side, back, etc.</TD></TR></TABLE>
Sounds dead center of the valve cover, its a more of a light tapping sound
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarfordCTR &raquo;</TD></TR><TR><TD CLASS="quote">Could be an injector</TD></TR></TABLE>
its not an injector sounds heavier
Old Dec 12, 2007 | 05:43 AM
Mikey3000's Avatar
pull the valve cover and take a look around. if u can't see anything turn the motor over by hand and maybe you can hear it.
Old Dec 13, 2007 | 05:26 PM
jetlude's Avatar
update: I pulled the valve cover and re adjusted the valve clearances.I also inspected the rocker arms lost motion assy. Every thing checks fine. I am beginning to wonder if the sound is actually coming from the block.
This sound is heavier than valve/injector tick but not as heavy as rod knock, almost like piston slap. Whats remarkable about it is, you only hear it at idle, and its louder when the engine is cold. once you rev past say 1500 you dont hear it. The slower the egine spins the more evident it is. Its not erratic but steady paced
Any other ideas?
Old Dec 13, 2007 | 05:36 PM
melovesboost's Avatar
could be a slight rod knock.
Old Dec 13, 2007 | 05:49 PM
jetlude's Avatar
Default Re: (melovesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost &raquo;</TD></TR><TR><TD CLASS="quote">could be a slight rod knock.</TD></TR></TABLE>
I dont think rod knock will disapear when the engine warms, or when you rev the engine.
Old Dec 13, 2007 | 05:58 PM
m R g S r's Avatar
sounds like piston slap...built motor?
Old Dec 14, 2007 | 03:40 AM
jetlude's Avatar
Default Re: Clicking sound from H22 after 3rd gear pull. WTF? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">sounds like piston slap...built motor?</TD></TR></TABLE>
Yea,its a built motor. I have always had a slight slap when cold, but all of sudden its distinctly louder. Car still runs perfect......just dont want to damage anything.
zccr-xsi
Feb 28, 2008 09:44 AM
Double Trouble
Apr 29, 2007 08:36 PM
Luchini
Jan 31, 2006 02:50 PM
IH82LOSE
Jul 21, 2004 02:45 PM
deconstruct
23
Jun 29, 2004 09:31 AM
