Best turbo for 400/500whp pump/race 60-1 60 Trim other?
Old Dec 11, 2007 | 10:11 PM
bootlegcivic's Avatar
Default Best turbo for 400/500whp pump/race 60-1 60 Trim other?
I'm trying to figure out the best turbo that will make 400-425whp on 93 octane then 500whp on 110 octane. The GT3076 seems to be the best but I dont want to spend the extra cash on the ball bearing turbo. So what I came up for choices are
T3 60-1 .63 AR $675
T3/T4 60 Trim .63 AR $555
T3/GT40 .63 AR $875
I've been searching on here/evans-tuning/synapse turbo for dyno sheets of the 60 Trim making 500whp but haven't found any.
Motor is a B16B converted to a 1.8L using LS internals. Will be cranking 9k.
If anyone has any other choices let me know. Quickest spool and easiest to make 500whp is all I'm looking for. I don't need more than 500 because I'm keeping stock sleeves.
Old Dec 12, 2007 | 03:30 AM
SIXTY-1HATCH's Avatar
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (bootlegcivic)
Go with the 60-1 w/ 82ar they have a sale on them on here somewhere for like 588 shipped. check it out, i personally run the turbo and it's supposed to be good for about 600hp max, so 500hp would be right in the "sweet spot" rang of the turbo. if you really think your gonna lean more toward 600hp go with a t3t67ho, best turbo up from the 60-1
Old Dec 12, 2007 | 04:07 AM
markaria's Avatar
The sc6152e is about $700 and can make well over 400 on pump and 500+ on race gas.
It should be a bit more efficient than a 60-1 as well. Good luck
Old Dec 12, 2007 | 04:26 AM
bzyq2001's Avatar
holset 351
Old Dec 12, 2007 | 05:42 AM
Schister66's Avatar
Man U FTW
An SC61 would get you there as would the 60-1; however, you might as well forget about getting 500whp out of a 60 trim because that turbo would be at its breaking point.
If money wasn't an option, i would suggest the Borg Warner S258
Old Dec 12, 2007 | 06:12 AM
Default Re: (Schister66)
Sc61 would probably be the best. Does anyone have dyno sheets or pressure plots for it.
Old Dec 12, 2007 | 06:23 AM
b16a4's Avatar
Default Re: (bootlegcivic)
the "Silver Surfer" will do what you want
aak theshodan
Old Dec 12, 2007 | 06:44 AM
Default Re: (b16a4)
by silver surfer you mean 60-1 right
Old Dec 12, 2007 | 06:57 AM
TTT's Avatar
TTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bootlegcivic &raquo;</TD></TR><TR><TD CLASS="quote">by silver surfer you mean 60-1 right</TD></TR></TABLE>
That is what the compressor wheel is, but the turbine wheel and the housings used are not the same ones that you see on 90% of the other 60-1 turbos out there.
Old Dec 12, 2007 | 07:51 AM
TheShodan's Avatar
Moderator
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (SIXTY-1HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY-1HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Go with the 60-1 w/ 82ar they have a sale on them on here somewhere for like 588 shipped. check it out, i personally run the turbo and it's supposed to be good for about 600hp max, so 500hp would be right in the "sweet spot" rang of the turbo. if you really think your gonna lean more toward 600hp go with a t3t67ho, best turbo up from the 60-1 </TD></TR></TABLE>
The "500" sweet spot is using the larger P-Trim wheel, not the one for $588. Those use a standard stage III, and go up to about 470whp or so, (and yes, I know someone here has one that made almost 600whp with it, but it was ONE pull on a dyno, and not at all the best way to use that turbo) then it doesn't like the wheel nearly as much. For the 60-1, use the P-Trim wheel. The Silver Surfer has the P-Trim wheel used.
Old Dec 12, 2007 | 03:27 PM
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (TheShodan)
does anyone have the link for the 60-1 for 588??<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
The "500" sweet spot is using the larger P-Trim wheel, not the one for $588. Those use a standard stage III, and go up to about 470whp or so, (and yes, I know someone here has one that made almost 600whp with it, but it was ONE pull on a dyno, and not at all the best way to use that turbo) then it doesn't like the wheel nearly as much. For the 60-1, use the P-Trim wheel. The Silver Surfer has the P-Trim wheel used.</TD></TR></TABLE>
Did you getany dyno sheets yet of the silver surfer??
Old Dec 12, 2007 | 05:07 PM
supergenius's Avatar
57 trim... GT40??? why in the hell is that ion there... that and they are t4 not t3
Old Dec 12, 2007 | 05:24 PM
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (supergenius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supergenius &raquo;</TD></TR><TR><TD CLASS="quote">57 trim... GT40??? why in the hell is that ion there... that and they are t4 not t3</TD></TR></TABLE>
I don't know if what you wrote makes sense but I will try to respond. 57 trim won't make 500whp and they make a T3/GT40 "blowzilla" my buddy runs one and went 10.6 on it at 131 making 510whphttp://cheapturbo.stores.yahoo.net/t3b.html
Old Dec 12, 2007 | 05:58 PM
My bad... Lol not farmilliar with the turbonetics ****. Missed the 500 on racegas part of the goal too!!! LOL
ya, 57 aint gonna do it!!
Holset can
LOL
I would think that a gt40 wheel on a t3 hot side would be laggier than ****, thought that the gt40 stuff was ALL big shaft as well... Actually i think it is. Educate me.
Old Dec 12, 2007 | 07:51 PM
Not sure the complete specs on the T3/GT40 but I know my friend that runs it spools faster than the 60-1 he used to run both .63AR
Old Dec 12, 2007 | 08:15 PM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supergenius &raquo;</TD></TR><TR><TD CLASS="quote">My bad... Lol not farmilliar with the turbonetics ****. Missed the 500 on racegas part of the goal too!!! LOL
Holset can
LOL
the t3/gt40 is similar to an sc61, gt35r compressor wheel, stage 3 or stage 5 exhaust wheels.
Old Dec 12, 2007 | 09:07 PM
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (mike@synapse motorsport)
ahhhhhhhhhhhhhhhhhhhh. So its a GT35 clone (SC 61)... NOT even close to a gt40... Thanks.
Modified by supergenius at 8:50 AM 12/13/2007
Old Dec 12, 2007 | 09:49 PM
Mike help me find a turbo!!! Do you think SC61 is the best?? Quickest spool out of these turbos is what I'm looking for. Unless you know someone selling a GT3076.
Old Dec 13, 2007 | 10:35 AM
bump for snow
Old Dec 13, 2007 | 10:53 AM
champLSinteg's Avatar
I just made 416 on 15psi with a t3/t4 60 trim .63ar with full 3in exhaust I am sure on race and upping the psi to 20+ will get me close to 500
Old Dec 13, 2007 | 10:58 AM
Default Re: Best turbo for 400/500whp pump/race 60-1 60 Trim other? (champLSinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">I just made 416 on 15psi with a t3/t4 60 trim .63ar with full 3in exhaust I am sure on race and upping the psi to 20+ will get me close to 500</TD></TR></TABLE>
I made 382whp at 17psi before on a b16a but I hate the fact that I can't find a dyno sheet of a 60 trim making 500 or close to it.
416 seems a little high for 15lbs. What kind of dyno were you on and whats your set up??
Old Dec 13, 2007 | 11:04 AM
FWIW... T4 PT6176SP (basically a t4 sc6176)
H22
17 PSI 516WHP 370 TQ on pump 92
Old Dec 13, 2007 | 11:22 AM
i think a 60-1 with a .63 a/r will suite you fine for 400whp dd and 500whp race gas setup. you have the good head, and with the 1.8 liter bottom end should be a decent street/strip setup.
Old Dec 13, 2007 | 01:30 PM
F*ck it 60-1 it is, Mike PM'ed for price
Old Dec 13, 2007 | 03:51 PM
gc8dc95's Avatar
Where is the 60-1 going to hit full boost with a .63a/r on a street LS setup?
