NEWB(i need intructions on Replacing a head gasket on a b18c5)
Anyone know where i can get specific instructions on how to replace a head gasket on a b18c5? any help would be greatly appreciated,Thanks
Buy a helms from http://www.helminc.com
By far the best investment. It will show you how to remove and replace everything along with some pics and torque specs.
Ali
Ali
Helms manual is worth the money. Haynes is not as good, but,,,,,,,
You didn't say why or how many miles on the RRRRR. But there are some things that should be replaced such as cam belt. Valve job?
No matter what, have a skim cut done on the head so that its perfectly flat and to ensure sealing. Mill off more to increase compression. If the head is off, clean up the ports?????
John
John
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">Buy a helms from http://www.helminc.com
Ali</TD></TR></TABLE>
Worth every penny.
Worth every penny.
Just make sure the side that says "UP" is UP (and make sure YOU check it, not one of your drunk *** friends who swears its on right...)
Otherwise you might wonder why oil is spewing out of your motor.
Franky61silv
Dec 18, 2007 09:31 AM
T--Rex
Oct 23, 2004 07:22 AM
