LCA's ?? SKUNK2???
ok been looking around now for a set of lca's for a dc. I found out in some other threads that they are really good. Now i have 1 question. 1. Anyone ever have any problems with these at all, like breaking or bushing problems or anything??? i know skunk2 is great company i just wanted to know if anything
I haven't heard of any aftermarket LCAs breaking under normal use. And I haven't heard about the Skunk2 bushings going out either. I mostly hear Omni bushings taking a crap, which happened to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">I haven't heard of any aftermarket LCAs breaking under normal use. And I haven't heard about the Skunk2 bushings going out either. I mostly hear Omni bushings taking a crap, which happened to me.</TD></TR></TABLE>
i've heard and seen the blox bushings go bad
Most of the low cost aftermarket rear LCAs use a cheap rubber bushing which has been reported to fail after a short amount of time. The more expensive alternatives like Function7 use a custom compound poly bushing which should last nearly the lifetime of the vehicle. And if it doesn't, they can be replaced very easily, and are warrantied for life. You could also get a stock set of LCAs for a tad bit less.
