BFG Drag Radials 205-50-15 (Street Slicks)
I have the following parts for sale and located in Torrance, CA.
-Camp1320 H22 Header (Not H2B Model): Been running this header for half a year now and it performs really well. This is one of the first units that camp started producing and the header put down good power and is holding up very well. There was a small dent on the bottom but I had it professionally repaired and it does not affect perfromance in any way. SOLD.
-NEW Evolution Industries PCV Adapter: Billet aluminum piece allows the PCV valve on an H22 to be repositioned and gives those with H2B swaps another 3/4" hood clearance so that you can avoid running hood spacers with the Evo kit and run a much smaller spacer with the QSD Kit. $35 shipped first class mail (2-3 day)
-NEW Innovative Billet Aluminum Mounts for Civic and Integra with B or D series motor: Billet Aluminum with the standard hardness inserts. For use with a 3 stud drivers side engine mount. $299 shipped.
-13" Lightweight Aluminum Spinwerks Wheels and MH Slicks: Wheels are super lightweight and are the same wheels that Bisi runs on his all motor insight. Tires have only been used for 2 events, have tons of meat left, and are 22X8X13.
$465
16" JDM Black Racing Phantom Wheels: Wheels are all in good condition except one that has a small bend on the lip. Wheel still holds air perfectly and is barely noticeable. Tires need to be replaced. $550
-BFG 205 50 15 Drag Radials: I used the tires for 3 Wednesday night drag events. Drove to and from the track on them and made about 3-4 passes on them each night so they are barely used. Switched out to full racing slicks so I no longer have a need for these. Other than that they were never driven on the street. SOLD.
-H22 California BAR kit: Comes complete with everything needed to pass CA BAR for H22 swapped civics and H2B swapped civics. Comes with AEM CARB legal intake and all sensors, wiring, etc... to get your swap legalized in the state of California. Get the piece of mind and save yourself the headache of getting harrassed by cops. You would also need a DC Header for your vehicle to pass, but those can be found for very cheap on HT. $200
Modified by Alchemist at 11:20 PM 12/13/2007
$465
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">
Thanks for the Bumps!!! BFG's and Camp1320 Header have been sold!
</TD></TR></TABLE>Thanks for the Bumps!!! BFG's and Camp1320 Header have been sold!
VtecKiDD
Performance
310
May 25, 2011 05:53 AM
VtecKiDD
102
Jan 7, 2009 07:38 PM
Alchemist
Mar 29, 2008 11:24 AM
