Does a integra type r (dc5) steering wheel fit on rsx
Does an integra type r (dc5) steering wheel fit on rsx, and wanted to know if i wont have a problem with the jdm air bag,like if the air bag light will be on or anything
yes it fits the USDM steering column and yes you will have a check SRS light on constantly because USDM is Dual Stage and JDM is Single stage airbags. Unless you take the JDM airbag out and replace it with the USDM you will have that blaring yellow light staring at you.
The ITR wheel fits, and a simple modification is needed to make the JDM airbag function properly. Check out this link below and read what I have to say at the bottom. If you have any questions, please ask. I'll be happy to clarify anything and to help you out.
https://honda-tech.com/zerothread?id=2160234
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Alex »</TD></TR><TR><TD CLASS="quote">is it like possible to just pop out the cover? or even switch it out with an ep3 sterring wheel?</TD></TR></TABLE>
I wouldn't do that, b/c if you do and you don't rivet it good enough and you get into an accident you're getting hit in the face with that hard plastic, and you might as well say goodnight at that point.
2nd question: Yes the EP3 wheel will fit fine and work properly (as long as its USDM).
risktypeS
16
May 25, 2007 07:59 AM
ejcivicdee
Jun 12, 2006 07:06 PM
