Would a stock 2003 civics cat fit on a 1995 civic?
Old Dec 11, 2007 | 01:24 PM
mike03,95civic's Avatar
Default Would a stock 2003 civics cat fit on a 1995 civic?
I'm having problems with smog. I need to get a stock cat to pass emissions. I have 2003 and a 1995 civic so i was wondering if it would fit.
Old Dec 11, 2007 | 01:25 PM
ca-rs's Avatar
Default Re: Would a stock 2003 civics cat fit on a 1995 civic? (mike03,95civic)
No, 02sensor is diff for one.
Old Dec 11, 2007 | 01:37 PM
Default Re: Would a stock 2003 civics cat fit on a 1995 civic? (ca-rs)
How would that effect the cat?
Old Dec 11, 2007 | 01:53 PM
eg6itr069's Avatar
well 2003 is for lev only...and plus it will not fit...if i am right there would be and o2 sensor located on the end of the cat...what is your reading for your smog result...
Old Dec 11, 2007 | 02:05 PM
Default Re: Would a stock 2003 civics cat fit on a 1995 civic? (eg6itr069)
Well i'm having it done through the BAR due to an engine swap. With the BAR my nox and hc are 2x the max, but i just got a pre test the hc was just a point over max. They let the car run for a while though. I drove the car long and hard for the BAR but they purposely let it sit. So man thats too bad it wouldn't fit... I guess i'll have to find another way.
Old Dec 11, 2007 | 02:07 PM
eg6itr069's Avatar
just put on a magnaflow one then...if you can try to retard your timing a lil bit...then you might be able to pass you smog with no problem...but knowing the bar they will definatly check your timing...damn jerk...lol..good luck
Old Dec 11, 2007 | 02:14 PM
It already has a magnaflow one on it. Yea i want to find out if theres any like range like 15-17 or something. lol...i know... thanks
Old Dec 11, 2007 | 05:39 PM
I know of a who has a stock '95 integra cat. Does any body know if a stock it would fit my '95 civic?
Old Dec 12, 2007 | 03:22 PM
Another question I have is I might have integra DC headers not honda (I bought the car with them). Since I have a b18 motor in the car would the headers have to be integra? Is '95 stock integra cat and '95 stock civic cat interchangable?
Old Dec 12, 2007 | 03:27 PM
sleeperrex's Avatar
the integ cat will fit if your running the b18. well id imagine u have integra header since its a b18....
Old Dec 12, 2007 | 05:05 PM
Default Re: Would a stock 2003 civics cat fit on a 1995 civic? (sleeperrex)
So if the headers are for an integra could I still use a stock civic cat... in other words do stock integra and stock civic cats have the same bolt locations?
thewrai6th
Feb 11, 2013 01:36 PM
FOMULA91
Jun 21, 2009 01:42 PM
maeofsj
Aug 31, 2008 11:17 PM
mike03,95civic
Honda Civic (2001 - 2005)
Dec 11, 2007 06:27 PM
b00sted4dr
Feb 1, 2003 09:45 AM
