Suspension & Brakes Theory, alignment, spring rates....
Quick DC2 Sway Bar Question
Old Dec 11, 2007 | 01:15 PM
goota's Avatar
Default Quick DC2 Sway Bar Question
Just a quick question so I know if im missing anything from what Im about to order:
1 Beaks Subframe Reinforcement Kit, 94-01 Integra, SRK-DC
http://www.heeltoeauto.com/pro...id=94
2 Comptech Replacement End Link For Comptech Integra/Civic sway bars 141-110
http://www.heeltoeauto.com/pro...45232
1 Beaks Prothane 22mm Bushings and D-brackets
http://www.heeltoeauto.com/pro...d=106
1 Beaks Subframe Tie Bar, 94-01 Integra, Rear, STB-DC
http://www.heeltoeauto.com/pro...id=98
1 Honda Genuine Sway Bar, Integra Type-R, 22mm, DC2
http://www.heeltoeauto.com/pro...=4806
From heeltoeauto.com, is there anything im missing to install them on my GSR? Thanks
Old Dec 11, 2007 | 02:54 PM
TastyDragon's Avatar
Default Re: Quick DC2 Sway Bar Question (goota)
looks good. i did tha 23mm sway bar on my gsr with asr subframe.
Old Dec 11, 2007 | 05:58 PM
goota's Avatar
yeah i was thinking of that, but this way I can get the Tie Bar also and it will be the same price as that.
Old Dec 11, 2007 | 11:38 PM
Default Re: (goota)
o another thing is tha asr brace seconds as a tie bar. just thought i'd let you know.
Old Dec 11, 2007 | 11:50 PM
toofast4u752's Avatar
and the ASR brace is 10X better at protecting from subframe tear out than the beaks.... people have still ripped their subframes even with the beaks..... the asr is 10X better and its better than any strut bar you can get for that.....
if its the same price to you than get the ASR brace..... asr runs huge(32mm+) sway bars on their braces all day with no problems.... yet people have still torn their subframes with the beaks kit along with just a typer R bar......... its your subframe..... rip it if you want to...
Old Dec 12, 2007 | 04:19 PM
goota's Avatar
hmmm thats good to know, thanks for the info, ill be getting the ASR.
Old Dec 13, 2007 | 12:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (toofast4u752)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toofast4u752 &raquo;</TD></TR><TR><TD CLASS="quote">and the ASR brace is 10X better at protecting from subframe tear out than the beaks.... people have still ripped their subframes even with the beaks..... the asr is 10X better and its better than any strut bar you can get for that.....
I'm pretty sure that the people who tore subframes w/ Beaks kits were 96-00 Civics which are known to have weaker subframes than 92-95 Civics and 94-01 Integras.
I've had a 22mm ITR sway bar with a Beaks kit for probably 3 years without issues. Before that I had the simple $20 BSQ kit without issues.
Oh, and don't bother with those Comptech end links. Your stock GS-R end links will work just fine as they did on mine.
Here is what I ordered from Son's Acura (list courtesy of BSQ's page http://geocities.com/bretq/swaybar_install.html ):
1.) 52300-ST7-Z01 rear swaybar ($68.94) Son's Acura price
2.) 52315-ST7-Z01 swaybar bushing ($4.08) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.66) (2 needed)
4.) 52316-ST7-Z00 sway bar end bushing ($1.60) (2 needed) Son's Acura price
5.) 52312-SE0-000 sway bar end bushing collar ($1.80) (2 needed) Son's Acura price – this part can be reused from the stock swaybar
But I substituted greasable Energy Suspension sway bar bushings in place of #2 and #3. These bushings have a grease fitting on the bracket so you can keep the grease fresh without unbolting the sway bar.
I think this along with the Beaks SRK-DC is the most cost-effective option. Then you can add the Beaks tie bar if you want to.
*edit* I edited the prices to reflect current Son's Acura prices. Get the sway bar from there as it's much cheaper than from Heel Toe.
roosie
Feb 18, 2019 05:03 AM
mish__
Suspension & Brakes
Aug 8, 2011 10:02 AM
carrnut21
Dec 12, 2006 07:40 PM
dc2integra
Suspension & Brakes
Sep 15, 2006 04:39 PM
mooook
Suspension & Brakes
Aug 7, 2005 03:53 AM
