99 Coupe - Will EK hatch door window/glass fit?
Old Dec 11, 2007 | 09:50 AM
I8ayellowcrayon's Avatar
Default 99 Coupe - Will EK hatch door window/glass fit?
Someone broke my passenger front window on my Si Its a '99 coupe; will a 96-00 HB passenger front window fit? My friend has one from a hatch, but I'm not sure if it will fit... The parts car is an hour away so I figured I'd check here first.
Old Dec 11, 2007 | 09:55 AM
714DC4's Avatar
Default Re: 99 Coupe - Will EK hatch door window/glass fit? (I8ayellowcrayon)
Well http://www.hondaautomotiveparts.com shows the si and dx windows as different parts numbers but I have a 99 hatchback DX with 99 Si doors on it so I am guessing it will fit.
Old Dec 11, 2007 | 11:45 AM
Yeah, I just looked up part numbers at HondaPartsDeals.com and it shows that the 2dr DX and the 3dr DX have the same part number, but for some reason the 2dr Si has a different number... Maybe the tint is a little different or the thickness is different....
Old Dec 11, 2007 | 02:25 PM
Sir Ash's Avatar
I think they should be the same since they use the same size doors.
Old Dec 11, 2007 | 02:59 PM
rpared01's Avatar
96-00 coupes and hatchbacks have the same doors, so the glass should be the same size. So you should be ok
Old Dec 12, 2007 | 02:17 PM
NOFX's Avatar
H-T White Ops
Yeah, I noticed awhile ago that the Si for some reason has a different part number than the other coupes and hatches. It's all the same shape though.
Old Dec 12, 2007 | 02:35 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: 99 Coupe - Will EK hatch door window/glass fit? (714DC4)
i asked the same question once and i got the answer in witch it stated that it's a different part number but that it would fit.
my .02 cents.
Old Dec 13, 2007 | 04:20 AM
It does fit. Really, I don't see any difference. It bolts up the same, no leaks... I wish I had the original to compare it to, but I'm sure its the same glass. And the color/tint looks exactly the same as well.
The car is a '99 Si coupe, and the RF door glass came from a 96-98 CX HB.
Old Dec 15, 2007 | 06:55 AM
MustWonder's Avatar
they are the same exact window i am 1000000% sure there is not differece
Old Dec 16, 2007 | 02:42 AM
sharik's Avatar
they will fit %1000000000000000000 the doors are the same, the doors on my hatch are off a coupe, i took them off my self at a junk yard
jtedrick
Oct 13, 2010 08:00 AM
christianc5692
Sep 15, 2010 05:32 AM
oneprelude
Apr 22, 2009 10:39 AM
e_dub
Jun 22, 2006 07:33 AM
sshaikh01
Feb 28, 2003 06:56 AM
