Trunk Floor Sound Deadner
Old Dec 10, 2007 | 11:52 PM
JohnD1079's Avatar
Default Trunk Floor Sound Deadner
That **** that you guys scrape off of the floor and trunk to save weight, its job is to insualte sound.
What is this stuff called, and where do you get it from?
Old Dec 11, 2007 | 03:15 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Trunk Floor Sound Deadner (JohnD1079)
I don't know what you would call the stock stuff other than sound deadening material but people serious about audio use stuff like Dynomat and other products that are similar.
Maybe you would get a better response from the A/V/S forum.
Old Dec 11, 2007 | 07:37 AM
TheMuffinMan's Avatar
He knows where you live!
It's essentially a tar compound.
If you want to replace it you've got a few options.
Dynamat Xtreme works well but is a complete bitch to remove (personal experience)
Breadboard (cheaper version of dynamat)
Roofing tar (sheets of actual asphalt/tar you roll in, smell goes away after about a week)
Do some googling and you can find a lot.
Old Dec 11, 2007 | 05:11 PM
JohnD1079's Avatar
Default Re: (TheMuffinMan)
well im not asking to find a cheaper version of dynamat.
A while back when the connection at my Fuel Sending unit(pump) was lose, instead of dropping the tank, we just cut the sheet metal to access it. I heard about the Tar crap you roll on. I will probably try that.
Old Dec 12, 2007 | 12:39 AM
Twixle's Avatar
ate my pixel
Default Re: (JohnD1079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnD1079 &raquo;</TD></TR><TR><TD CLASS="quote">well im not asking to find a cheaper version of dynamat.
A while back when the connection at my Fuel Sending unit(pump) was lose, instead of dropping the tank, we just cut the sheet metal to access it. I heard about the Tar crap you roll on. I will probably try that. </TD></TR></TABLE>
Cutting near the gas tank, great idea.
BlackJacket
10
Nov 11, 2013 02:33 PM
:jdmshmaydm:
Aug 3, 2004 05:02 AM
Steve91
18
May 29, 2002 06:38 AM
boomslang
Sep 29, 2001 01:05 PM
raene
Jun 6, 2001 08:25 AM
