pretty neat sequential twin turbo set up (2jz)
wow ... just wow ... I don't know where to begin:
1) A single will make more power
2) Just about ANY other type of header will flow better
3) Why?
Yes, the finished product looks great, but what exactly has been achieved here other than saying "look what I did"? Am I missing something here?
3) Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dave@passenger »</TD></TR><TR><TD CLASS="quote">Wow there are so many thing wrong with that setup I don't even want to get started.</TD></TR></TABLE>
Care to elaborate?
Care to elaborate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">are the runners exiting the ports of the head conjoined?</TD></TR></TABLE>
appears to be so...looks like a log mani w/ runners for each port going to the turbo's....and a 44 gate split from the middle & end of the log...and then for some reason they have the 38mm on the exh side of the other turbo...my only guess is to block exh gases? and create a bigger pressure differential across the other turbine?
Yes.
That is so when the valve is shut (look at the number two turbo downpipe - front turbo) it forces all gasses to the number one turbo for quick spool.
This is how you can achieve 17psi at 2100rpm on a Supra.
Once the valve is opened in the downpipe, both turbos operate in "true twin" form.
Yes.
why would they have th 38mm bypassing the valve on the front turbo? thats a vacume actuated valve, so i'm asuming it opens at the same rate as the wastegate.
well, unless they are using all stock vacume routing with this setup?
looks cool, but if i went to all that trouble i would have run a compound sequential setup. one feeding the other.
grose, i just saw the log portion
i believe either bmw or mercedes is running a sequential setup on one of their new diesel engines they are developing. the thought behind it is to make power earlier in the power band, not to just make it up top with one big turbo. i'd love to see a dyno plot off this setup.
edit: read here... http://www.autospeed.com/cms/A_2544/article.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manifoldmiketyson »</TD></TR><TR><TD CLASS="quote">
This setup was designed for super quick spool, a compound turbo setup is just for really high boost levels. They serve two completely different purposes.
Considering the working confines of the system, very well done. However, there are a lot of areas that could see improvement. For example, given more room with wich to work in, a better wastegate setup could be fabricated. The wastegate in this case is fed by one of the flange collector tubes. This forces the gases to make an extreme 135+ degree turn in order to BEGIN to exit. I won't even start on the fact that the wastegate vent tube is IN the collector vs. after it. But like I said, give the parameters under which the system had to fit, awesome fabrication job!
I too would like to see a dyno plot of the setup vs. a medium single "well spooling" turbo for the same engine.
Modified by FastCougar at 12:39 PM 12/11/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
This setup was designed for super quick spool, a compound turbo setup is just for really high boost levels. They serve two completely different purposes.</TD></TR></TABLE>
Actually compounds when done right spool a lot faster than any single and are obviously much more capable of making more pressure.
I hope they install a longer intake on the rear turbo atleast so its not sucking in the first ones turbine housing heat! Anyway, a little to much work for me then just doing a single but I believe that would be a killer road race setup!! thanks for Sharing.
I feel like im looking at a maze
