d16z6 in a 98 DX. What else do i need?
Old Dec 10, 2007 | 06:28 PM
jdmsohc2nr's Avatar
Default d16z6 in a 98 DX. What else do i need?
I am putting my fully built turbo d16z6 into my 98 dx coupe and i know there are a few things that need to be done. I may be missing a few things though. I already have purchased a ecu conversion harness to run my chipped p28. I have also purchased the dizzy conversion harness. I am a little confused as to how i am going to run the throttle cable. Do you suggest using a wheel off a F22 IM or just getting a 98 EX throttle cable? axles i am almost sure are the same as well as motor mounts. Any input would help. I want to be prepared 100% for this swap. Thanks in advance.
Old Dec 11, 2007 | 05:14 PM
jdmsohc2nr's Avatar
Default Re: d16z6 in a 98 DX. What else do i need? (jdmsohc2nr)
come on. No one has ever put a d16z6 into a 98 chassis??
Old Dec 11, 2007 | 05:33 PM
bigslickek's Avatar
how much you get the motor for? or how much did it cost to build?
Old Dec 11, 2007 | 06:13 PM
jdmsohc2nr's Avatar
Default Re: d16z6 in a 98 DX. What else do i need? (bigslickek)
what difference does it make? i built the motor myself. it was out of my 93 ex (first car) i took it out built it and put maybe 14k miles on it and now i wanna put it in a cleaner shell. my 98 dx.
Old Dec 13, 2007 | 05:05 PM
jdmsohc2nr's Avatar
bump bump.. what do i have to do for the driver side mount? and can the dx throttle cable be used?
Old Dec 13, 2007 | 05:13 PM
96teggylsse's Avatar
axels will work.. mount a little different. search for it... you pretty much got everything else i believe
Old Dec 13, 2007 | 08:19 PM
jdmsohc2nr's Avatar
i have searched.. i cant find anything. i cant believe that this is a uncommon swap. I don't see one post about anyone putting a z6 into a 98 DX.
1fatcrxnem1
May 28, 2008 07:32 PM
jdmsohc2nr
Feb 28, 2008 05:12 PM
fventura03
May 26, 2006 08:23 AM
zeroracerh
Apr 21, 2003 11:47 PM
