sfwd b-series part out
I have too many projects and not enough time to finish everything, so decided to get rid of one,
All of the used items are in like-new conditioin. Pics available upon request. If paypal is used please add 3.3% no trades
AIM is bluehatch00 if have any questions
- -10 return line for full-race topmount $40 -10 sockless
-full-race downpipe for topmount, vband 3-4" downpipe coated - $500obo
-fluidampner bseries race pulley (alternator only) -$330obo
-p14 obd1 prelude ecu - $50
-competiton 12lb steel flywheel bseries - used- $100obo
-skunk2 p61 OBD1 93 gsr ecu - 150obo
-b20 bare block w/ main caps needs to be 85mm or great core for sleeving - $100obo
Kseries stuff
-exedy stage 1 k series clutch used for dyno -$150
-stock EP diff with bearings -$100obo
Stuff sold soo far!!
-03 type-s 6speed trans 3500miles - SOLD
-Gsr trans with quaife - SOLD
-aeromotive eliminator pump - SOLD
precision 750hp intercooler USED for dyno - SOLD
-JG intake manifold GSR head for 8 injectors new in box & fuel rail for
2nd set - SOLD
-garrett t4/67 ptrim S cover .84 divided exhaust housing - SOLD
-Sleeved 84mm gsr bottom end, manley rods, gsr crank, custom CP pistons
new oil pump, bearings, thrust washers - SOLD
-MT 24.5x9x13 slicks used 7 passes - SOLD
-hondata s300 in p28 socketed by hondata - SOLD
-tial 44 gate (silver) new 13lb (big blue) spring - SOLD
-tial 44 gate (silver) used 1bar springs (big red/small red) - SOLD
-Precision 750hp intercooler new in plastic - SOLD
-Cncported GSR head, supertech SS coated intake and inconel exhaust valves and valvetrain complete with cam caps, no dizzy no IM - SOLD
-DSS stage 5 axles and hubs already installed in knuckle for Bseries in
EG/DC - SOLD
-tial 50mm bov silver - SOLD
-ported JG manifold for b18c accepts 70mm tb -SOLD
-precision PT70 GTQ H cover .81 coated exhaust housing - SOLD
-Turbo xs manual boost controoler single stage - SOLD
-01 ITR cams and venom cam gears - SOLD
-ARP headstuds GSR new - SOLD
-precision 1000cc injectors - SOLD
-RPM services 70mm TB with tps - SOLD
-cometic 84mm bseries vtec headgasket(new) - SOLD
-arp extended wheel studs new in packages - SOLD
-bseries venom cam gears - SOLD
-motor mount inserts new in box - SOLD
-AEM 5bar map sensor used -SOLD
-sleeved 84mm B16 block, LS crank, eagle rods, custom arias pistons with raised pin 13:1
compression - SOLD
-B18C head skunk2 flat valves, skunk springs and retainers complete -SOLD
-00-01 ITR cams - SOLD
-GSR arp headstuds USED - SOLD
-omnipower clutch master cylinder NEW - SOLD
- -10 return line for full-race ramhorn,socketless - SOLD
-B&M fuel reg new in plastic - SOLD
-obd1 gsr dizzy- SOLD
-MSD cap - SOLD
-full-race t4 sidemount manifold for EG tial 44 flange - SOLD
Modified by T4eg at 9:19 PM 5/6/2008
Kseries stuff
2nd set - SOLD
EG/DC - SOLD
compression - SOLD
-MSD cap - SOLD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_117 »</TD></TR><TR><TD CLASS="quote">Bump for viewing, lots of nice parts! </TD></TR></TABLE>
thanks! bump
thanks! bump
01 ITR cams and venom cam gears - $400obo?
are those the cams listed below? same cams just prices without camgears?
00-01 ITR cams $300?
im interested in just the cams.
-RPM services 70mm TB with tps - $225obo
-B18C head skunk2 flat valves, skunk springs and retainers complete with cam caps -$600obo
can i get pics of those 4 things sent on here in a pm or to my email mikerodgers007@comcast.net
-arp extended wheel studs - $30 new
ARP headstuds GSR new - $115obo
and im interested in those as well
pm me so we can talk prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetnbyu93 »</TD></TR><TR><TD CLASS="quote">bump for chris
thanks pat, PMs returned.
</TD></TR></TABLE>thanks pat, PMs returned.
