"Clutch pedal stays low" Help asap
when i depress my clutch pedal it shifts fine but it wont return back up i have to lift it with my foot then it stays up , but its a new problem that been happenin the fuid is fine level havent found any leaks
The clutch master cylinder is the one attached to the firewall. The slave cylinder is the one attached to the transmission.
Many times the master cylinder will leak down the firewall inside the cabin. Check for fluid there also.
Could be your clutch master cylinder or slave cylinder...same thing was happening when i had my accord and it turned out the clutch master cylinder had gone bad so i replaced it...g/l
ianae86
Mar 16, 2006 01:59 AM
siregcivic
Oct 16, 2005 07:55 PM
