Swaping B18C-R from EG to EK
Cool Cool Island Breezes. BOY-EE
You need a 99-00 Si rear mount. As long as the brackets that attatch to the engine and trans itself are present, all your driver's side mounts from your D series will work.
Use the trans brackets from the B series.
Also, your B18C5 should have allready come with OBD2 injectors and distributor.
You will need to change some intake manifold harness plugs. You will need to change the orientation of the IAC wires. The orange one gets deleted...you'll have to look up what exactly to do with the other 2 to get the IAC to work. It's been a long time since I did the swap.
4drferio
Aug 28, 2007 07:39 AM
