Round EK Fog lights.....install process.
Old Dec 10, 2007 | 08:30 AM
crx_si-r's Avatar
Default Round EK Fog lights.....install process....FINISHED WITH PICTURES
well i just bought a set of DEPO brand round fog lights at the local swap meet. they are new and never been used. but for $20 i figured what the hell. ill put em on. so as soon as i get out of class today which will be in a 1 1/2hr ill be installing them and takin pics of everything so u guys can see my progress. so keep a look out for the thread when i make it.
Modified by crx_si-r at 1:04 AM 12/11/2007
Old Dec 10, 2007 | 09:06 AM
crx_si-r's Avatar
Default Re: Round EK Fog lights.....install process. (crx_si-r)
ok here is a pic that i got off ebay of the Fog Light Kit that i will be installing.....
Fog Lights
What it should look like installed...not my car found it online...
Old Dec 10, 2007 | 09:50 AM
lowfast's Avatar
Should be easy. GL
Old Dec 10, 2007 | 10:55 PM
crx_si-r's Avatar
Default Re: (lowfast)
yea im pretty sure it will be easy. i like to take detailed pics of what i do, so others who have questions about it can look it up on here. i usually roll more in the EF forum and post all my projects on there. so here are the pics quick before and after...
before...
after...
Old Dec 11, 2007 | 12:32 AM
crx_si-r's Avatar
Default Re: (crx_si-r)
ok here we go....
here is what i started with DEPO brand round foglight kit bought at the local swap meet for only $20.00
97 EK coupe before fog lights....
first i started off by removing the 7 upper retaining screws..
next remove the 2 screws located under the fenderwell..
then remove the 2 lower 10mm bolts that hold the bumper to the chasis...
once those bolts have been removed pry the bumper off the vehicle...
now its time for some cutting...
before..
after....this is where what i needed to remove..
after cutting...
backside..
front side..
after cutting i bolted up the fog light bracket to the appropriate spots on the bumper..
front side..
back side..
next i chose this spot where the main harness is to locate the relay....
i then ran the harness that connects to both the battery and relay through this hole located under the stock air intake box...
after that i then decided to connect the ground cable by the driver side headlight....
i then ran the other part of the harness through the same first hole but on the driver side...
now onto the harness under the dashboard...
there are 3 screws that need to be removed...
screw #1
screw #2
screw #3
i then ran the power cable through this plug here located under the clutch master cylinder in the engine bay...
dash side...
engine bay side..
after running the power cable i connected the the plug in the #5 slot on the fuse box...
i then ran the ground wire for the under dash harness onto this spot here located at the end of the dashboard...
almost done now. just neatly tuck all the wires into a safe spot...make sure to leave enough room for the sunroof/power window switches....
now re-install the lower dash cover, making sure to pull out enough wires so that you are later able to connect the fog light switch and push it back in...
u are now done. just re-install the front bumper and bolt up the fog lights and plug them into the harness....
now some night time lit up pics...
And thats all now u just have to wait till its darker out and aim the lights appropiately.
Old Dec 11, 2007 | 04:24 AM
B16B_coupe's Avatar
HRD PKR
not a bad write up man!!!
Old Dec 11, 2007 | 08:28 AM
crx_si-r's Avatar
Default Re: Round EK Fog lights.....install process. (B16B_coupe)
thanks. it was fairly simple. only took about 1hr 50min. i coulda finished sooner but i was takin pics of everything. if i didnt take some pics i think i coulda finished in just over 1hr 15min.
Old Dec 11, 2007 | 09:08 AM
lowfast's Avatar
Looks good to me. for you
Old Dec 11, 2007 | 09:37 AM
HondamanXxX's Avatar
GO GIANTS!
gOOD JOB MAN.
Old Apr 19, 2008 | 01:14 PM
Drew17th's Avatar
Default Re: Round EK Fog lights.....install process....FINISHED WITH PICTURES (crx_si-r)
looks good!!
Old Nov 8, 2010 | 06:15 PM
otek // ek.dipn's Avatar
looks awesome i have the square kit i cant really figure out how the mounting brackets go =| anyone wanna post a pic for me? thannnnk you ahead of time!
Old Jun 9, 2011 | 10:02 PM
jawsuu's Avatar
this really helped me out thanks.
Old Jun 13, 2011 | 02:57 PM
crx_si-r's Avatar
no prob. glad it could be of help
Old Jan 3, 2014 | 09:53 AM
xenex99's Avatar
Awesome!! just what i was looking for! great job man!
Cnile1
56
Nov 2, 2010 09:17 PM
SUCIO D_BOY
Jun 23, 2008 04:42 PM
KDMandJDM
27
May 31, 2007 07:39 PM
RFX
Nov 21, 2002 02:01 PM
