replacing brake hardlines
Old Dec 9, 2007 | 10:54 PM
86mmboosted_da's Avatar
Default replacing brake hardlines
hey guys, newbie here, I lurk alot and dont post much, but I searched already and couldn't find what I was looking for or find it within the 700 or so posts that came up. So here goes; I want to replace my brake hardlines in the engine bay to ss braided. What connector do I use from line to flare? and what size line would be ideal?
I know its controversial, but I just want to finish my da up and this is the route I would like to go. I already removed the abs, and got the 40/40 prop valve.
I thought this was in the Pandahatch thread, but for some reason I did't see it.
thanks for your help.
Old Dec 9, 2007 | 11:36 PM
crowder13's Avatar
look in apperance
Old Dec 10, 2007 | 12:21 AM
Default Re: (crowder13)
thanks found a good point to start. and I'm getting closer
Old Dec 10, 2007 | 06:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why do you want to replace your non-flexible brake lines to line that will possibly flex more than stock and reduce braking performance?
Old Dec 10, 2007 | 09:18 AM
LIMITLESS22's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want to replace your non-flexible brake lines to line that will possibly flex more than stock and reduce braking performance? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86mmboosted_da &raquo;</TD></TR><TR><TD CLASS="quote">
I know its controversial, but I just want to finish my da up and this is the route I would like to go.</TD></TR></TABLE>
Who cares its his car.
Old Dec 10, 2007 | 09:54 AM
Hawkze_2.3's Avatar
Default Re: replacing brake hardlines (86mmboosted_da)
Use -3AN line, 10mm hydro adaptors and fittings as needed, and 45, 90, 180, etc degree AN fittings as you need them. I made a custom SS clutch line from Summit and it has worked perfect so far...
jdmark1
Jun 22, 2018 03:37 PM
BoostinEJ1
11
May 21, 2006 09:38 AM
Pandahatch
Welding / Fabrication
36
Feb 17, 2006 01:13 PM
