BLOX THROTTLE BODY INSTALL QUESTION
Old Dec 9, 2007 | 10:01 PM
c1_inside's Avatar
Modified by c1_inside at 12:37 AM 12/17/2007
Old Dec 10, 2007 | 02:53 AM
DaveF's Avatar
Default Re: BLOX THROTTLE BODY INSTALL QUESTION (c1_inside)
pics would be a help. what kind of parts did they give you ? block off plates for IAC + map ?
Old Dec 10, 2007 | 05:02 PM
hamst3r3x's Avatar
every thing is the same tps, map, and vac's the throttle just looks different the cable go's on the same way
Old Dec 12, 2007 | 08:38 AM
JakeSpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1_inside &raquo;</TD></TR><TR><TD CLASS="quote">I RECENTLY BOUGHT A BLOX 68MM THROTTLE BODY FOR MY GSR....I HAVE A SKUNK2 MANIFOLD ...CAN SOMEONE TELL ME HOW TO INSTALL THE THROTTLE BECAUSE I USED TO HAVE THOSE THROTTLES THAT LOOKS OEM BUT THIS BLOX ONE IS A BIT DIFFERENT AND BRINGS SOME PARTS THAT ARE SUPPOSED TO BE INSTALLED BUT I DONT KNOW WHERE.......THANKS</TD></TR></TABLE>
you need to use existing throttle cable and the cable leaf bracket bolted onto your oem throttle body
use the 2 10mm bolts to fasten the leaf bracket on your new TB and it should be a go
Old Dec 12, 2007 | 05:55 PM
c1_inside's Avatar
THE PARTS THAT ARE NEXT TO THE THROTTLE ARE THE ONES THAT I DONT KNOW WHERE TO PUT INSTALL THEM IN THE THROTTLE.....
Old Dec 12, 2007 | 06:09 PM
HR-1320's Avatar
It looks like replacment bolts for the tps and map, clamps for the water lines and a 90 deg fitting that srews into the throttle body fro the water line and I can't see the other pieces that well. If I'm right just from a glance your a knuckle head and may wanna seek a profesional for installation.
Old Dec 12, 2007 | 07:03 PM
JakeSpec's Avatar
Default Re: BLOX THROTTLE BODY INSTALL QUESTION (HR-1320)
[QUOTE=HR-1320]
I need a LS Crank
i have a LS crank In the Garage, Its A spare 60$ + Shipping
Old Dec 14, 2007 | 11:48 AM
TDautowerkes's Avatar
Default Re: BLOX THROTTLE BODY INSTALL QUESTION (JakeSpec)
the 2 sided nipple is for the coolant bypass....
recliner15
Mar 6, 2014 01:09 PM
c1_inside
Dec 13, 2007 09:15 AM
hamst3r3x
Dec 10, 2007 09:41 PM
dLo GSR-stolen-now-WRX
Mar 24, 2002 05:44 PM
