02 sensor question
Old Dec 9, 2007 | 05:32 PM
boostedjdmdc2's Avatar
Default 02 sensor question
Would a faulty 02 sensor cause an engines idle to feather? like jump up and down from 800-1500? on a jdm b16
Old Dec 9, 2007 | 11:12 PM
bump
Old Dec 9, 2007 | 11:13 PM
SLO Sol's Avatar
Default Re: (boostedjdmdc2)
it could
Old Dec 9, 2007 | 11:20 PM
Hardedge's Avatar
I don't understand how it could. The O2 sensor is only used to help the ECU make on-the-fly fuel delivery adjustments based on exhaust oxygen content. I believe that if the sensor fails, the ECU will run on a pre-programmed fuel map that essentially always runs rich to be safe. I don't think this will cause an idle surge. Check for leaks around the throttle body and intake manifold.
Old Dec 9, 2007 | 11:22 PM
fmrprojects's Avatar
Default Re: (Hardedge)
check for vacumm leaks or bad iac valve
Old Dec 9, 2007 | 11:57 PM
jmsp EG'zer's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">check for vacumm leaks or bad iac valve</TD></TR></TABLE>
what he said. or if your running a chipped ecu it could be the ecu.
StraightCivic
10
Apr 5, 2006 12:27 PM
Zekueterna
Jan 2, 2005 11:34 AM
tylek17
Jan 7, 2004 09:24 PM
clean
Oct 8, 2001 04:20 PM
