I'M bored tell me what you think
Old Jun 26, 2002 | 06:21 PM
civbeater90's Avatar
Default I'M bored tell me what you think
[Modified by civbeater90, 4:11 AM 6/27/2002]
[Modified by civbeater90, 4:12 AM 6/27/2002]
Old Jun 26, 2002 | 06:22 PM
Default Re: I'M bored tell me what you think (civbeater90)
http://www.imagestation.com/mypictur...tion=block%206
i still don;t know how to put pics up
Old Jun 26, 2002 | 06:31 PM
EFCIVIC_810's Avatar
wow!!!! thats is beautiful.man that shyt looks nice. man, wat size turbo??? have fun and good luck cuz the shyt is looking beautiful man!!!!!!!! later
Old Jun 26, 2002 | 06:41 PM
Default Re: I'M bored tell me what you think (EFCIVIC_810)
well looks like i'm going t3/t04e 57 trim .etc.thanks for the compliment.here is another shot of the block from the front.the pic is hitty it's actually alittle nicer in person,it's powdercoated like a candy aplle red.
http://www.imagestation.com/mypictur...tion=block%204
Old Jun 26, 2002 | 06:58 PM
Default Re: I'M bored tell me what you think (Lil Cs Zc)
can you please explain how you post the pic?
Old Jun 26, 2002 | 07:05 PM
.Ryan's Avatar
Don't Trust Anyone
If your building it to prove to someone that you can. Would that mean I can tell you "I think you could build it", would you stop?
To post pics you right click a pic on a website, go to properties, copy and address link of the pic, then on post/reply, click image then place the address link between the image thingy's. it should work then.
Old Jun 26, 2002 | 07:08 PM
Default Re: I'M bored tell me what you think (SpoonSportsEF7)
ok thanks for the explanation.iv'e tried that and it shows a little square with a red x.what am i doing wrong?
Old Jun 26, 2002 | 07:12 PM
.Ryan's Avatar
Don't Trust Anyone
I dunno buddy.
Old Jun 26, 2002 | 07:43 PM
90_Civic_Hatch's Avatar
Hoe did you polish the valve cover?....if you did do it your self
Old Jun 26, 2002 | 08:31 PM
Denny317's Avatar
looks real clean. good job
Old Jun 26, 2002 | 08:50 PM
maskednegator's Avatar
right on man. nice to see something different.
Old Jun 26, 2002 | 09:10 PM
89 CRX SI's Avatar
Default Re: I'M bored tell me what you think (maskednegator)
through image station when you right click dont select the last pat that is .orig.jpg or somthing just have one .jpg thats all.
Old Jun 26, 2002 | 09:25 PM
DJ KrunchyKracker's Avatar
Default Re: I'M bored tell me what you think (Denny317)
that is one of the most beautifullest things in the world
Old Jun 26, 2002 | 09:59 PM
spettinger's Avatar
Default Re: I'M bored tell me what you think (TheRZA28)
what is it that you are proving you can do? spend a lot of money? check. good luck with the project. looks nice.
Old Jun 26, 2002 | 11:31 PM
ef civic's Avatar
Default Re: I'M bored tell me what you think (wreckedhatch)
here you go
Old Jun 27, 2002 | 12:45 AM
shortyz's Avatar
Default Re: I'M bored tell me what you think (ef civic)
very nice
what intake is that?
Old Jun 27, 2002 | 03:37 AM
Bleed Black's Avatar
Default Re: I'M bored tell me what you think (shortyz)
That better not be going in show car! Get it together and woop up on some people at the track.
Old Jun 27, 2002 | 05:58 AM
SpooN Man's Avatar
duh STR
Old Jun 27, 2002 | 10:35 AM
Home Skillet's Avatar
here you go
I can eat off this thing.
Old Jun 27, 2002 | 04:04 PM
Default Re: I'M bored tell me what you think (Home Skillet)
ok for starters,to all the compliments thanks you.ok when i polished it i basically started with a high speed grinder with a scocth brite pad.then i started wet sanding using coarse grit moving my way down to finer.once it got sorta polished i use some stuff called blue majic(autozone)then it was just of matter of using a lot of rubbing and wax.everything has been covered with carnuba wax to help keep it bling bling.um yes this setup will be used at the track.
to answer the other question.a certain individual doubted my work ethic.so in order to shut this shi_ talker up i am building a turbochargerd sohc and the car has been completly stripped down to nothing.once i get it back from the body shop i will post before and afters.
but once again thanks for all the compliments,its kinda cool to see some people actaully appreciate something instead of alwyas just talking shizzy.
rule!
Old Jun 27, 2002 | 05:05 PM
Loaded Butane's Avatar
Nice work man.
What kind of HP or times you shootin for?
Old Jun 27, 2002 | 06:18 PM
Default Re: I'M bored tell me what you think (Loaded Butane)
realistically,i'm looking for 12's and i'll be happy.as long as the car is reliable.i will be happy with low 12's.i don't think it's too hard to achieve considering i have a ton of stuff for my setup.too much stuff too list,but you can assume the usuals,turbo,engine mangement etc.
Old Jun 27, 2002 | 07:13 PM
Mr.JaCkeL26's Avatar
Nice work man.
yea looks good!! yea post pics of your car with the times!!
Old Jun 27, 2002 | 07:31 PM
Good luck man it looks like your on the way to me.
Old Jun 27, 2002 | 07:41 PM
USteppin's Avatar
looks like a volvo block =P
