Honda Garage Clean Up D16Y8 motor/tranny, EG & Da Parts & Misc... (Pix Inside)
Old Dec 9, 2007 | 01:53 PM
SlowIntegra's Avatar
Default Honda Garage Clean Up D16Y8 motor/tranny, EG & Da Parts & Misc... (Pix Inside)
<U>BUMP IF VIEW</U>
Will Trade for HX rims or Tein S-tech springs
Everything is OBO
d16y8 shortblock-----------100
hydro D-series tranny----------------100
d16y8 head with mani------------100
D-series starter-------------20
EG tails------------------40
EG headlights-----------------40
obd-1 vtec harness------------------40
DC cargo cover-----------------10
b & d-series clutch engament piston----------40
DA Headlights------20
DA fogs----------40
DA red/white Tails---------60
1 EF/ 2 da rad support brakets----------20
obd-0 pr4 ls 5speed ecu-------30
DA controls----------------20
DA power mirrors-----------40
DA cluster with 78 miles--------40
DA cluster bazel with buttom and vents------40
DA rear body filler------------30
DA moldings with clips-----20
DA steering cover----10
DA hood latch braket & Latch unit---------30
DA steering wheel------------20
Da mud gurdes------------30
also got EG mud gurdes
Da clutch cable--------------20
DA speedo cable--------------20
DA ingention with key-------------40
DA ingention with key & trank lock-------------60
DA front bumper mounting brakets-------20
DA mirror inside covers-----------10
Da T braket n tq---------------------20
Ek driver side mirror non-power-----20
B-series lower timing belt cover---10
B-series PP-----------20
CRX si springs (fronts are cut)-------------20
Altanator Brakets------20
B & D-series ac compressors------20 each
EF ac line-----------------60
B-series PR3 ac brakets-------10
Braket Master cyc DA Rs & Gs, bottom is DC2 Ls------40 each
Civic EX calipers------------------60
Civic EX New front rotors--------------40
D-series valve cover----------20
JDM B18c-3 Sir-G valve cover--------------40
LS valve cover-------------------20
B-series ps top mount braket-------10
B-series PS pump-----------10
IAC--------------10 each
Honda Metal cooling Fan (Good for turbos)------20
LS head studs-------------------20
B-series Crank main cap studs-------------20
DC2 Passenger side fender----------30
E-brake lines braket-----------10
codrulz
Nov 18, 2012 08:02 AM
my94ram
Aug 6, 2004 06:33 PM
weaselchew
Dec 18, 2002 06:29 AM
