Code 43 Fuel supply system
Old Dec 9, 2007 | 12:36 PM
teg_racer's Avatar
Default Code 43 Fuel supply system
what is this and how do i fix it.
causing my car to run really lean and the idle fluctuates
Old Dec 10, 2007 | 08:13 PM
teg_racer's Avatar
Default Re: Code 43 Fuel supply system (teg_racer)
eh?
Old Dec 11, 2007 | 01:36 AM
Outkast95LS's Avatar
bad injectors? clogged fuel filter? bad fuel pump?
Old Dec 11, 2007 | 10:24 AM
Relic1's Avatar
90% of the time that code is caused by your O2 starting to go bad.
ECU sees either too much fuel or too little, tries to adjust, O2 doesn't respond correctly, ECU sets this CEL.
But since the ECU still sees an O2 signal it doesn't set the O2 CEL.
Old Dec 11, 2007 | 09:46 PM
teg_racer's Avatar
Default Re: (Relic1)
i tried two diff o2 sonsors. one off an obd2 gsr motor and the other was a stock one for my car, didnt change anything,... im thinking maybe my fuel pump is going bad but if it were going bad it shouldnt run... after startup idle it fluctuates
TomCurllyFry
Dec 2, 2012 08:50 PM
Skip01
Jun 20, 2009 09:22 PM
civiccarbuff
Sep 18, 2008 08:29 PM
DualCamEK
10
Dec 25, 2004 08:01 AM
importimage
Jun 30, 2003 04:27 PM
