Need help identifying connectors (pix inside) 1991 accord
Old Dec 9, 2007 | 10:47 AM
aleks77's Avatar
Default Need help identifying connectors (pix inside) 1991 accord
I posted on cb7tuner but didnt get much response at all...
hey guys as some of u know im doing my wire tuck, well my lazy *** finally made some progress and now im ready to re-run the wires, however i forgot where some of these connectors connect to lol so if you can help me out that be great basically i need to know which connectors are running outside of the fenders to the front of the car, which are stayin in the bay, which are goin inside the car (fusebox is goin inside the car, i know which connectors run to it).
Thanks for any help! Also the first imagine i need help with!
Modified by aleks77 at 9:57 PM 12/10/2007
Old Dec 9, 2007 | 02:29 PM
Hawkze_2.3's Avatar
Default Re: Need help identifying connectors (pix inside) 1991 accord (aleks77)
I know #4 and #8 are ground connectors (hence the black wires). You need to bolt that ring on there to a good ground spot on the frame.
The rest I don't know for sure, but usually they will only fit one other connector, you just have to do trial and error to match them up. If you do have 2 coonectors that are the same, then just match up the wire colors going into the connectors and you're set.
Old Dec 9, 2007 | 10:16 PM
aleks77's Avatar
the engine is out of the bay, i cant really plug it into anything....and i have to know if i have to run them to the front or leave them in the back of the engine bay before the engine goes in...
Old Dec 10, 2007 | 08:55 PM
aleks77's Avatar
anyone know?
rosewood66
Honda Motorcycles
Oct 26, 2009 05:08 AM
goose32
Classic Hondas
May 11, 2008 04:29 PM
krytoi
Mar 19, 2007 01:22 PM
juanb
Welding / Fabrication
12
Mar 26, 2006 05:52 PM
