need some color codes for some plugs. IACV, IAT
hi i swapped a b18b1 into a 93' cx hatch and i have been looking around on here all morning for some wiring color codes. the wires i need identified are the IACV, IAT, and there is one more plug that is similar.
well... i just want to make sure i have the right plugs and not switched around. if anyone can identify the wire colors for those plug that would be nice. also what the third plug goes into? thanks.
I need this too, I keep searching and cant find, I have 2 plugs that are the same I just need to know which color wires are for the IACV
Bump, I'm having the same problem. I swapped a 98 B18B into my 92 cx and I have 3 plugs on my OBDI harness that have the same connectors. 1 isn't being used, the other two go on the IAT and the IACV, but I cannot figure out which plug goes where.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">iat= red/yellow, iacv=green/white</TD></TR></TABLE>
Mine from obd1 ecu pinout, so if its obd1 and on the ecu side thats what it is
(assuming they're the same from the ecu through eng. harness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serio_ENDLESS »</TD></TR><TR><TD CLASS="quote">iat green/red
iacv blue/black</TD></TR></TABLE>
What are yours for the engine harness?
Modified by z6hatchboy at 9:47 PM 12/21/2007
hi! OP here!
anyways a little update since people bumped for same questions.
Car is a '93 Hatch cx that i bought that came with a DX d15b7.
motor installed was a '94 b18b1.
As of right now, my car is running PERFECT. I have NO CEL's. I have driven over 900km(jdm cluster) in the past week(got it running perfect last Sunday 12/16). I commute 65miles one way everyday. MY IAT is yellow and red while my IACV is blue and yellow. The mystery third plug... is still a mystery... lol
My IACV threw codes even though the valve was removed and cleaned and i had the right plug. I fixed this by cleaning the connectors/plugs with wd-40, dried, then applied Dielectric grease that can be bought at any parts store for less than 2 dollars.
I had a roaming idle that was fixed by taking apart and cleaning the FITV and screwing the white plastic piece all the way in. This was when I also cleaned the IACV.
My fifth gear always poped out during fifth. There wasn't enough tranny fluid. so i added more Honda MTF. Problem fixed.
These were some of the problems I had and how i fixed them since alot of people are undergoing almost the same swap and might encounter the same problems. I hope this helps people to get their car running for the holidays. If anyone has anymore questions, feel free to ask or pm me.
for the holidays!
for the holidays!
pigeonkiller22
Nov 30, 2008 05:23 PM
dohdoh420
Sep 11, 2006 10:30 AM
