bazooka tube directly to deck.
Old Dec 9, 2007 | 09:26 AM
chris3k's Avatar
Default bazooka tube directly to deck.
sooo i have a bazooka tube sitting in my garage, im pretty sure its non amplified. the rear has these connections . do you guys think it would be safe to connect directly to my pioneer deck? and if i did would it even work?
Old Dec 9, 2007 | 09:54 AM
B18C_EJ8's Avatar
Safe? Sure... If it's a 4 ohm sub, it'll work.
Work well? Probably not. It'll produce some sound, but it really needs to be amped.
Old Dec 9, 2007 | 01:08 PM
fcm's Avatar
fcm
Old Fart
Default Re: bazooka tube directly to deck. (chris3k)
Ditto the above ^^^, it will work, you will get sound, however it will not be very loud and it will be full-range, you need an amp so you can get some power, [watts] to it, and at low-pass. 94
Old Dec 9, 2007 | 03:39 PM
chris3k's Avatar
alright, thats what i thought, im just going to wait around for christmas money and buy some quality stuff that will be super solid. thanks for the info.
Old Dec 10, 2007 | 04:05 PM
toadaddy's Avatar
I was thinking the same thing... you can set up the rear output to sub on the pioneer deck. What if you wired it to an efficient sub/mid and used the built in crossover to have the fronts playing just highs? I know it wouldn't be the best set-up, but hey...
Old Dec 11, 2007 | 05:33 AM
standbackimapro's Avatar
Well since bazooka tubes suck.. and the amplified ones have like 50 watt amps...
You can get an amp for that for like 60 bucks dosnt have to be anything special.
But ive heard bazooka tubes in some hatches and they sound pretty mean
Old Dec 11, 2007 | 09:41 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toadaddy &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking the same thing... you can set up the rear output to sub on the pioneer deck. What if you wired it to an efficient sub/mid and used the built in crossover to have the fronts playing just highs? I know it wouldn't be the best set-up, but hey...</TD></TR></TABLE>
No you can't... the RCA (Sub) output's are not amplified at all, its just signal.
Old Dec 11, 2007 | 11:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
No you can't... the RCA (Sub) output's are not amplified at all, its just signal. </TD></TR></TABLE> Yes you can, on some Pioneer HUs the rear speaker outputs could be used for a small sub. 94
Old Dec 11, 2007 | 11:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yes you can, on some Pioneer HUs the rear speaker outputs could be used for a small sub. 94</TD></TR></TABLE>
Really? Handy.
In that case, powering a tube might be okay.
JDMB20TDA
Audio / Security / Video
21
Sep 24, 2009 02:14 PM
sjbmx
Jul 2, 2008 02:33 PM
nappyroots827
Dec 20, 2006 07:11 PM
LudemanDan
Aug 2, 2005 08:16 AM
95redcivicex
Sep 11, 2002 08:04 AM
