ls vtec problem
ls vtec problem
i have an ls vtec swap in a 93 hatch....i was runnin fine wit a gsr tranny but wen i switch it to a b16 tranny....the hatch feels like its not gettin enough power...i wont pass 2000 rpm...and idk why....my car getz stuck at 2000 rpm...plzz help..
Cool Cool Island Breezes. BOY-EE
you switched some plugs around or something. What all did you unplug? Did you replug the speed sensor in? all the grounds? Did you unplug any other sensors on the actual motor or the intake manifold? The VTEC/CTS, and MAP/TPS plugs are the same. If they get switched around (it happens a lot), the car runs badly.
What CELs are on?
What CELs are on?
im not sure if they switch some cables or sensors...because i took it to a shop...ima look it up...i have a gsr head and the only problem i had is the is that the car idle alot...but that was no biggie...thanx for ur help...if u think of anything else that can help meh...REPLY thanx
