check engine light and vtec wont work?
Old Dec 8, 2007 | 09:05 PM
msinsky14's Avatar
Default check engine light and vtec wont work?
i searched and didnt find anything because this is really weird. I was driving my 88 crx si with b16 and it would never warm up enough to hit vtec. it has never had any problems before. the temp. needle is lower than usual, and other than it not hitting vtec it drives normally.
any ideas of what thos could be?
Old Dec 8, 2007 | 09:08 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: check engine light and vtec wont work? (msinsky14)
What code are you throwing?
Old Dec 8, 2007 | 09:22 PM
msinsky14's Avatar
Default Re: check engine light and vtec wont work? (***$nyper)
my ecu is being retarded. if i knew i wouldnt be asking. the led isnt blinking and neither is the CEL.
im trying to figure this out, it just randomly is not warming up(or at least is saying its not warmed up), and its redlining at 6.8K like a non-vtec motor.
Old Dec 8, 2007 | 09:27 PM
Ass$nyper's Avatar
ok then how do you know there is a code?
Have you checked your cooling system?
Is your fan always on ?
Old Dec 8, 2007 | 09:28 PM
msinsky14's Avatar
i havent checked my fan. i was thinking its maybe the thermostat or i need to bleed the cooling system, but why would either cause the check engine light to come on?
Old Dec 8, 2007 | 09:29 PM
msinsky14's Avatar
also if this helps, when i brake hard or turn a corner fast the oil light comes on and goes off really quick, if that helps.
i dont know what that is
Old Dec 8, 2007 | 09:30 PM
SIred91's Avatar
Rainman
Bad thermostat and or coolant temp sensor?
Change the thermostat anyway and see what happens.
Old Dec 8, 2007 | 09:31 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">also if this helps, when i brake hard or turn a corner fast the oil light comes on and goes off really quick, if that helps.
i dont know what that is </TD></TR></TABLE> Check your oil level.
As SIred said, try changing the T-stat.
Old Dec 8, 2007 | 09:33 PM
SIred91's Avatar
Rainman
That could be nothing...*bad ground* or it could be bad news.....
Oil level oK?
Do you burn oil a lot?
Old Dec 8, 2007 | 09:43 PM
msinsky14's Avatar
Default Re: check engine light and vtec wont work? (SIred91)
I'll check my oil level in the morning.
what u mean it could be bad news?
Old Dec 8, 2007 | 09:47 PM
SIred91's Avatar
Rainman
Losing oil pressure is never good. And vtec operates of off oil pressure.
Old Dec 8, 2007 | 09:50 PM
msinsky14's Avatar
yea i kno that, but the oil light only comes on whenim braking hard or turning a corner hard. seems really weird.
could low oil cause the check engine light?
Old Dec 8, 2007 | 09:51 PM
msinsky14's Avatar
ive aslo been getting bad gas mileage if that helps.
im worried
Old Dec 9, 2007 | 03:59 AM
xxnickpxx's Avatar
yeah thats not good, if its not oil, the it could possibly be speedo, i forgot to connect mine once and vtec wouldnt kick.
check your oil often, im worried for you man.......
Old Dec 9, 2007 | 06:29 PM
msinsky14's Avatar
Default Re: check engine light and vtec wont work? (xxnickpxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxnickpxx &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats not good, if its not oil, the it could possibly be speedo, i forgot to connect mine once and vtec wouldnt kick.
check your oil often, im worried for you man.......</TD></TR></TABLE>
dont say that please....
i also noticed, my oil is a quart low and it smells like gas, so i just think the oil is burning away since its running rich as hell. i smell gas and oil burning out the exhaust.
Old Dec 9, 2007 | 08:41 PM
Si-Samuri's Avatar
uh oh. better stop trying to redline it before you figure out whats wrong.
Old Dec 10, 2007 | 12:25 AM
xxnickpxx's Avatar
i also noticed, my oil is a quart low and it smells like gas, so i just think the oil is burning away since its running rich as hell. i smell gas and oil burning out the exhaust.</TD></TR></TABLE>
wait, so you mean to say your oil smells like gas?
if so, yeah you are burning rich. thats not good for alot of things.
Old Dec 10, 2007 | 01:18 AM
clockwork675's Avatar
first question, how long since an oil change? second, does your car burn oil
third, if the oil smells like gas when was the last time you did a tune up? cap, wires, plugs?
Old Dec 10, 2007 | 01:41 AM
Under Con. CrX's Avatar
Default Re: (clockwork675)
do you have a after market FPR have you checked your timing on both the belt and dizzy there is a lot of things to look for in this situation
Old Dec 10, 2007 | 11:53 AM
msinsky14's Avatar
Default Re: (Under Con. CrX)
i did a full tune up about 2K ago. oil is burning as well. i just added 1.5 quarts. my last oil change was 2K ago also. i kno im burning rich because i smell gas coming out of my muffler. I'll get a shop to check this one out, im clueless.
Old Dec 10, 2007 | 12:00 PM
801ef's Avatar
Default Re: (msinsky14)
my 86 prelude..who was a beauty.. would make the oil light come on when i ripped the e brake lol but i never figured out why..so when i sold it i didnt say anythin lol
Old Dec 10, 2007 | 01:05 PM
ludesrv's Avatar
Default Re: (801ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 801ef &raquo;</TD></TR><TR><TD CLASS="quote">my 86 prelude..who was a beauty.. would make the oil light come on when i ripped the e brake lol but i never figured out why..so when i sold it i didnt say anythin lol </TD></TR></TABLE>
Thanks for the most useless info ever.
Kid, you need to do some serious run downs on your engine. Oil light coming on, if the sensor is not broken (seen it happen), basically means you ran your engine dry of oil, almost. The oil light comes on when you oil pressure sensor cannot sense oil pressure. I would look into getting a digital oil pressure sensor from a shop and testing to make sure the oil pump isn't dead.
Old Dec 10, 2007 | 02:49 PM
msinsky14's Avatar
Default Re: (ludesrv)
ok so heres the deal, after driving it down to the shop to get the fuel pressure tested, the bguy said he doesnt think thats the problem.
underneath my dizzy, the headgasket is leaking oil, which also has the gas smell.
he said that can cause a car to run rish since its burning oil in the cylinders and the o2 sensor has a screwed up reading, causing it to run rich.
tell me if that sounds alright, i have never worked with that particular guy before.
Old Dec 10, 2007 | 07:46 PM
xxnickpxx's Avatar
sounds about right, didnt know you had an oil leak. thats probly your culprate
Old Dec 10, 2007 | 07:49 PM
agree with nickp, my advice though is if your gonna pay to get it repaire and not do it yourself try going to a few different shops and choose one you feel comfortable at
