Need fog light wiring diagram
Bought JDM Password style foglights for my 92 hatch. All the hard parts were there, have them on the car, but i cannot seem to figure out the wiring. Battery and relay installed on passenger side, switch in dash. Where does the two yellow wires with the ring connector go? Does anyone have the diagram or install instructions? JDM would not help, already called them.
hmmm i don't recall any yellow wires with ring connectors...
from what i remember off the top of my head is...
from the engine bay
1. there is a power wire directly from battery or fuse box.
2. then goes to fuse
3. from there is the fog light plugs with a ground ring.
4. goes up the other side of the engine bay into the cabin.
inside cabin
5. connects to second part of harness
6. one ground from the relay.
7. one into fuse (optional plug socket)
8. one to switch.
this was an ebay 92-95 oem style kit.
from the engine bay
inside cabin
8. one to switch.
Thanks for the responses, looked at the honda link, mine is not the elaborate. It had a switch harness that came out to the drivers side strut tower with a black wire with a ring terminal(assumed to be a ground), a red with a bullet connector(connects to the other half of the harness-from battery AND foglights) and then these two yellows with the ring.
ME=ADRIAN
Jun 28, 2007 03:24 PM
