jdm b16 with bigg a$$ vtec solenoid
what is the difference besides the size. I have two b16a heads and one vtec solenoid is wayyy bigger them the other one. Anyone have any info about this post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">TTIWWOP</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHswaps13203 »</TD></TR><TR><TD CLASS="quote">no its not jdm obd0 b16 came with the bigger solenoid. it pops vtaK Mad HaRdER yO</TD></TR></TABLE>
Correct, i think it uses a different gasket too (91 nsx if i remember correct)
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
Correct, i think it uses a different gasket too (91 nsx if i remember correct)</TD></TR></TABLE>
no thats incorrect. it is the same cylinder head therefore the gasket is the same. i owned both
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Renegade »</TD></TR><TR><TD CLASS="quote">it can use a nsx gasket. went to get a gasket for my obd0 b-16 back in the day and the guy i knew there said that the nsx's fit better.</TD></TR></TABLE>
Though so
Though so
i just tryed to replace mine with a obd1 gaskey and it was to thin..... the gaskets for the soilenoid is def different but the spool valves are the same
Guess im not incorrect
</TD></TR></TABLE>Guess im not incorrect
I can vouch for 1st gen B16A (obd)) being a larger solinoid than other gens. I have both a 1st b16 and a 2000 model B18C5, and they are in fact different sizes.
They are interchangable though as they both bolt up to the same casting head.
Here a couple crappy shots of the 1st gen B16 one, its just a little fatter than the new ones
i know for a fact that the Vtec solenoid gasket from obd will not work with obdI, the obd0 is thinner, but the place it sits in is also thin, the obdI is fat two fat, and also the corners are different, there is a thread about the differences. And yea you can use the NSX one but only on the obd jdm, you can try to track down a civic one, but yo its the same ****, the nsx doesnt have a better one the same one. if you expletive up and put the fatter one it will rip and youll loose all of your oil through you vtec solenoid, trust me it has happened
This is the size of a real JDM solenoid, same size as the NSX
https://honda-tech.com/zerothread/2173498
