90' Civic Si HEATING and STARTING problems
Old Dec 8, 2007 | 06:23 PM
Colombiano127's Avatar
Default 90' Civic Si HEATING and STARTING problems
I recently bought my first car back from my sister.
The car sat for 3yrs atleast....
1st issued:
- The battery light came on while the car was running.. to check if the alternator was working I started the car and disconnected the battery, the car stayed on, I gas a little-bit and it died. I connected the battery back and tryed to start and now I wont..... What can be the issued?
2nd issued: (It was happening when the car was running)
- The car would overheat, I changed the thermostat and It stopped but the next day it did it again. When I would start the car the radiator fluid would bubble up and flush into the reservoir. The car overheats at different speeds, the exhaust is Smokey white and has a different smell than regular exhaust. What can it be?
I talked to a guy and he said it sounds like a blown head gasket....
Help me out guys...
Old Dec 8, 2007 | 07:00 PM
rd91sib18c5r's Avatar
Default Re: 90' Civic Si HEATING and STARTING problems (Colombiano127)
Sounds like a blown headgasket, And check your
Old Dec 8, 2007 | 07:13 PM
stunn'd's Avatar
lol, check your main fuse... if the internal regulator in the alternator is pooched, if might have gave your car 19 some volts. Btw, disconnecting the battery when the car is running is <U>not</U> the proper way to test an alternator..
Old Dec 9, 2007 | 06:32 AM
thevtecnician's Avatar
Default Re: 90' Civic Si HEATING and STARTING problems (stunn'd)
Not trying to be a jerk here but what is the 'correct way' to test it? Care to enlighten us? I've been using the poor boy method a while and it seems to work fine. Lol
Old Dec 9, 2007 | 06:35 AM
Fuzzy Rhubarb's Avatar
take it to autozone, they'll test starters and alts for free.
Old Dec 9, 2007 | 10:36 AM
Default Re: 90' Civic Si HEATING and STARTING problems (thevtecnician)
thats what I was told afterwards...
Old Dec 9, 2007 | 10:38 AM
Default Re: 90' Civic Si HEATING and STARTING problems (rd91sib18c5r)
Theres some fuses in the engine conpartment and one did blow out but I dont know what they control.....
The lid doesnt have a diagram and the book I have doesnt show either...?
My_EFsedan
17
Jan 22, 2012 12:43 PM
sannay562
14
Jul 5, 2008 09:14 AM
dwan
Oct 8, 2007 06:30 PM
antiricer
13
Jan 20, 2007 02:52 PM
alfaaay
Aug 15, 2003 01:47 PM
