OEM 99-00 fogs install question. Hole saw size
Old Dec 8, 2007 | 01:58 PM
actek23's Avatar
Default OEM 99-00 fogs install question. Hole saw size
In the instructions it says i need a 40 mm= 1.5 diameter hole saw to drill the holes into the bumper...I was looking around the garage and found a 2 inch diameter hole saw. Instead of going to the store to buy the 1.5 inch diameter hole saw, can i get by with this 2 inch hole saw? Thanks.
Old Dec 8, 2007 | 02:11 PM
angel_i's Avatar
i wouldnt try it
Old Dec 8, 2007 | 03:11 PM
RyanA's Avatar
Default Re: (angel_i)
Yes, I'd recommend getting the right hole saw. Since the little dots on the back of the bumper mark the center of a 1.5" hole, if you do a 2" hole, your end hole (after you "connect the dots" and make the big hole) would be too large for the bezel to cover.
Old Dec 8, 2007 | 03:29 PM
actek23's Avatar
Default Re: (RyanA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanA &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I'd recommend getting the right hole saw. Since the little dots on the back of the bumper mark the center of a 1.5" hole, if you do a 2" hole, your end hole (after you "connect the dots" and make the big hole) would be too large for the bezel to cover.</TD></TR></TABLE>
but if you think about it... the difference between the 1.5 inch hole saw and the 2 inch is a matter of a 1/4 of an inch from the center... maybe if i just move the holes where i'm suppose to drill a 1/4 of an inch closer too the middle away from the actual "+" spots where i'm suppose to drill, i could be fine.
Old Dec 8, 2007 | 04:46 PM
RyanA's Avatar
Default Re: (actek23)
Yes, you would be fine as long as you are very **** laying out the hole. Take your time and be careful and all should end well.
gsr_84
Feb 27, 2009 07:04 AM
JSiRTO
16
Jan 19, 2008 12:03 AM
Supraznki
Apr 12, 2005 03:18 AM
harryg
Nov 25, 2002 12:01 PM
Gump
May 4, 2002 04:29 PM
